Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Suspension > Suspension Marketplace
Old 12-31-2014, 03:11 PM   #101
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt Forward Arm Series - Sale
Originally Posted by PBFAB.COM View Post
Those ball joints are not fully seated. You will be required to press them into the cup.
We have seen this before, as the lower lip on certain ball joints does not fit into the recess on the lower cup. It keeps the ball joint from being fully seated in the cup.
I will see if I can't dig up a pic to send you. And also source a part number for a ball joint that we know fits.
Nate
Scoti-
Also, please continue this correspondence through email, as it will allow me to more efficiently follow up with you and track the conversation. I don't make it over here to the forum as frequently as I would like, and we need to run all TECH related questions through the email. You can feel free to post the responses and resolution here in this thread if you would like.
Thanks,
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 12-31-2014, 03:59 PM   #102
SCOTI
SCOTI's Avatar
Scoti-
Thanks,
Nate
Will do.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
90SWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
Old 01-01-2015, 06:14 PM   #103
SCOTI
SCOTI's Avatar
Nate
To follow-up.... This was exactly the problem.
The base flange OD for my Moog BJ was too large to fit within the cup on the PB a-arm. Of course, this same flange seats against the lip on an OE arm so I figured when I installed it in the PB arm it was a similar type install/fit. The reality is the brand that PB recommends have a smaller OD & fit within the cup w/o issue.
Nate offered assistance throughout the day as we worked toward a solution & suggested ordering their recommended BJ. Since mine were brand new Moog units I was determined to come up w/a solution & make them work. I measured the ID of the cup on the PB arm & then the OD of the Moog BJ w/a caliper. I put the BJ on a bench grinder & turned it down until the base OD was within a few thousanths. After that, I pressed it in w/no issue.
Since it was just the base interfering, the serrated portion that secures the joint wasn't impacted so no strength was lost. With the BJ pressed in further & seated properly, there is enough @ the top that the rubber dust boot has something to positively locate it.
Happy New Year!
67SWB-B.B.RetroRod
64SWB-Recycle
90SWB Driver
All Fleetsides
Old 01-01-2015, 07:21 PM   #104
gringoloco
A guy with a truck
gringoloco's Avatar
Good info! Any pics of correct fit?
-Chris
'72 K/5 Highlander How To: Ruin a Perfectly Good K/5
'70 Short-Wide How to: Ruin a perfectly good C10
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (Moved to Canada)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69
gringoloco is offline   Reply With Quote
Old 01-01-2015, 09:42 PM   #105
SCOTI
SCOTI's Avatar
Yes..... But I can't put them up yet (they're on my work computer). I will later tonight or tomorrow in the am.
67SWB-B.B.RetroRod
64SWB-Recycle
90SWB Driver
All Fleetsides
Old 01-02-2015, 10:34 AM   #106
SCOTI
SCOTI's Avatar
Ball joint fully seated....
67SWB-B.B.RetroRod
64SWB-Recycle
90SWB Driver
All Fleetsides
Old 01-02-2015, 10:38 AM   #107
SCOTI
SCOTI's Avatar
Rubber dust boot seated @ base of stud.....
67SWB-B.B.RetroRod
64SWB-Recycle
90SWB Driver
All Fleetsides
Old 01-02-2015, 11:49 AM   #108
Popcorn W
Popcorn W's Avatar
Looking at your website, the lowers start at $699 now?
Popcorn W is offline   Reply With Quote
Old 01-02-2015, 05:40 PM   #109
PBFAB.COM
PBFAB.COM's Avatar
Correct. The lowers start at $699... but there are a couple add-ons and upgrades that could raise it a little if they are selected.
The C20/C30 arms are an additional $75 and will include ball joints on all orders placed after 1/1/15.
Feel free to shoot us an email with any other questions you might have!
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-06-2015, 12:59 PM   #110
jus2qwk
jus2qwk's Avatar
sorry to bring up an old thread but if you are running these control arms with the stock crossmember, what is the best place to put a bump stop if you didnt want the truck to go all the way down? currently my tires are hitting the fenders and I dont think I want it quite that low so I can use factory inner fenders.
Corey Jones Designs
CoreyJonesDesigns on instagram
Ole Silver- 1967 stepside
http://www.hotrod.com/articles/1103c...chevrolet-c10/
http://67-72chevytrucks.com/vboard/s...d.php?t=598758
jus2qwk is offline   Reply With Quote
Old 12-30-2015, 01:07 AM   #111
SierraMtns
Tagged for later
SierraMtns is offline   Reply With Quote
Old 02-12-2016, 08:25 PM   #112
kitsbeach
kitsbeach's Avatar
Nate
I used the ball joints that Porterbuilt sold me with the arms. And they look to me to be fully seated. But there is not enough of the ball joint protruding for the rubber boot to attach.
Any ideas.? Other than machining the porterbuilt arms down.?
Name:  Photo 2016-02-12, 3 57 27 PM.jpg
Kitsbeach (Ken)
1967 C10 LWB Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
kitsbeach is offline   Reply With Quote
Old 02-13-2016, 12:26 AM   #113
kitsbeach
kitsbeach's Avatar
Attachment 1498609
Got an answer form Nate himself already (on a Friday night!). Thanks Nate.!
Ken-
The dust boot seats nicely against the machine face of the ball joint cup with the spindle installed.
It's not a grease boot designed to hold in the grease, but rather a dust boot that prevents water and debris from entering the joint.
Install as is and move forward!
Nate
Kitsbeach (Ken)
Old 03-15-2017, 05:26 PM   #114
SBTork
Garage wrench
SBTork's Avatar
I couldn't find these on the PBFAB website, are these still being made and is there still a deal on them?
-Adam
85 C10 Suburban 5.3 / 4L60E on air, three season DD, rockin the southern GA patina.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 03-15-2017, 05:31 PM   #115
PBFAB.COM
PBFAB.COM's Avatar
http://pbfab.com/porterbuilt-tubular-control-arms
In the drop down you can select ball joint placement. Or email sales@pbfab.com
Thank you
Dave
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
