11-26-2018, 01:03 AM | #1 |
Front accessory drive kits
What’s everyone using for front accessory drive kits, I like the Holley mid mount system but I’m not running a/c so that one won’t work for me. And it needs to be corvette parts do to space. Thanks!
*sorry forgot to say it was a 6.0l* Last edited by obie16; 11-26-2018 at 08:48 AM. Reason: Forgot to mention engine size |
11-26-2018, 11:11 AM | #3 |
Re: Front accessory drive kits
I used the same set up as NorCalGal. I got mine off a 93 GMC. Used the same water pump and everything off the parts truck. |
11-26-2018, 11:36 AM | #4 |
Me too. Parts were from a 1999 S10 with 4.3 engine. You can also buy an AC eliminator kit which provides an idler pulley where the AC compressor mounts.
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes |
11-26-2018, 02:39 PM | #5 |
Check out ICT billet. Thats who i went with. Lots of options cheaper than most of the rest. Quality is top notch.
current ride 1951 AD Chevy 5 window 2004 LS Gen 3 [/B] 1965 fleetside Sold |
11-26-2018, 04:40 PM | #6 |
Just another opinion but I used factory stock on my Task Force. You mostly never see the serpentine system, or at least not much of it. If you want it to be "pretty" you can have the upper pulleys or brackets polished. this is what I plan to do with mine....eventually.
I bought Vintage Air's polished AC compressor and Drier
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
11-26-2018, 07:08 PM | #7 |
i made all of mine for less than $15 mostly for bolts
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
11-26-2018, 07:16 PM | #8 |
for your edit, try
https://www.gmperformancemotor.com/category/LS2202.html specifically https://www.gmperformancemotor.com/parts/19257325.html also try https://www.lssimple.net/ specifically https://www.lssimple.net/purchase-co...rnator-no-belt
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
11-27-2018, 05:59 PM | #9 |
Another Holley option is this https://www.holley.com/products/acce...s/parts/20-143
Though the alternator will likely get into the left inner fender. If I remember correctly you have the option for fore aft spacing too for truck, Camaro or Corvette. |
