Old 04-24-2019, 06:19 PM   #1
Tom
driving is in my blood
Tom's Avatar
tail gate handle issue? 98 gmc
The tail gate handle to release the gate is crooked on my truck and some times I have to reach in and pull the left side release rod more because just using the handle doesn't pull it enough. The handle is not broken or flexing, and looks to be mounted perfectly strait. Anyone else have this issue? What was the fix?
-02 Suburban 4x4: stock
Old 04-24-2019, 07:18 PM   #2
shifty
Questionable
shifty's Avatar
Re: tail gate handle issue? 98 gmc
You have one of these clips on each bar to the latch. (don't buy the one I linked, there are less expensive packs out there)
They're not bulletproof. They eventually can fail. I suspect the one may be bad on yours.
All you need to do to confirm whether this is the case with yours is to snap out the trim piece around the handle itself. Then watch the motion of things as you pull up on the handle.
I can't remember what attaches the metal bar to the latch plunger itself - there may be another one on the plunger/latch mechanism side you can't see. If so, you can only get to that by removing the latch mechanism on the affected side.
Even if you don't see me actively posting, I'm probably still around. Drop me a PM.
shifty is offline   Reply With Quote
Old 04-25-2019, 09:25 AM   #3
95 S_Trucker
95 S_Trucker's Avatar
I’ve also had to bend the rod to make it a little shorter
-99 K2500 LS CCSB 7.4
-11 GMC 2500HD SLE CCSB 6.0
-96 C3500 HD 7.4 NV4500 Rollback
-85 K10 5.7 700r4
-78 K10 5.7 4 Speed
-90 ZR1 5.7 6 Speed
-62 Lincoln Sedan 430 Auto
-61 Lincoln Convertable 430 Auto
85 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=368864
78 Big10 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=383629
96 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=614515
95 S_Trucker is online now   Reply With Quote
Old 04-25-2019, 10:33 AM   #4
speedygonzales
speedygonzales's Avatar
It's usually the clips
Generally the length of the rods doesn't grow over time so if the problem is new, it's usually the clips that are on both ends of each rod. The clips can still be there but worn in the inside (pulling direction) of the rods.
When this happens, the rods have to move further than normal and sometimes appear to be short. That is, not pulling enough to open the tailgate.
The clips are available from a variety of sources in the help aisle from Dorman
https://www.oreillyauto.com/detail/b...e+Handle&pos=0
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 04-26-2019, 07:18 PM   #5
71gmcC15
71gmcC15's Avatar
Order a new trim peace to. Your going brake the clips that hold it in. Even if you think you whant you will. They are quite easy to brake.
71 gmc c15 307 sbc 373 rear gears positrac m20 trans
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
71gmcC15 is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
