Old 01-20-2015, 06:22 PM   #1
775stepside
Rear glass removal?
Are all rear glasses on 88-98 Silverado just have the seal around the glass or do they have the glue? I plan on switching my wife's 89 sliding window to just a single glass? I have to pull it so I'm curious I have taken windows out before but I figure the ones with just the seal around it are easier to take off?
775stepside is offline   Reply With Quote
Old 01-20-2015, 08:34 PM   #2
lester622
Re: Rear glass removal?
Its glued in with eurothane and has to be cut out. You can buy the blade that goes on the end of a sawsall and try it yourself but you have to be careful because the blade will cut through the metal. Easier to call a glass guy out and have them cut it out and put the new one in.
You can try to cut it out with a window knife also but it takes forever and you can scratch the glass if not careful.
lester622 is offline   Reply With Quote
Old 01-20-2015, 08:56 PM   #3
775stepside
Ok thanks I'll figure something out I'll buy a tool to get it out
Old 01-20-2015, 09:12 PM   #4
775stepside
Will a glass off a 91 pickup fit the same on a 89?
Old 01-20-2015, 09:33 PM   #5
lester622
This is the blade for the sawsall, There not really cheap and if you get one use soap and water in a spray bottle or glass cleaner to keep it moving free on the glass when cutting.
glasses are the same from 89-98 as long as its the same body style
Old 01-20-2015, 11:09 PM   #6
775stepside
Ok thanks man for all the help, and I thought I swear there was some rear glasses with just the seal orotund the glass
Old 05-13-2019, 09:54 AM   #7
rockosocko
How'd it turn out?
I have a '95 2500 that I want to replace my slider with a flat, NON slider. (latch was broke years ago and one side replaced with plexi-glass)
BUT when I started to take it apart, the window frame looks like it would be easier to just find another cab with a flat then to pull that slider frame out lol..
Was trying to be gentile but dang!!!#(*&^$@*#@)
Maybe a heat gun would help?
Did you guys have to pull the interior plastic out?
This is what I purchased. I think it was a good deal. Plus it's tinted already so I won't get sunburn..
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
rockosocko is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
