Old 07-09-2019, 10:40 PM   #26
WorkinLonghorn
WorkinLonghorn's Avatar
Re: NP435 questions
Originally Posted by Dave64 View Post
Weim55,
Steve,
I may not have made myself clear, but the HOUSING I have here is for the TAPERED ROLLER bearing.
Depending on whom you're talking to, the Chev/GMC version DID NOT use the tapered roller type, yet they are listed in the Chev/GMC parts list???
If worse comes to worst, I would have to also get a housing that suits the flat roller race, but believe I can get away with the tapered roller type housing that I have here.
Hope that makes it a bit clearer.
Cheers, Dave64
Dave, GM used 2 different NP435s. Usually the light duty option was the close-ratio model and some C-30s and the C-40-60 got the wide ratio one. But there is a guy on this forum who has the wide ratio on his C20 and says it is stock. I don't know about the bearings but it could be that the wide ratio one has the tappered rollers. Here look at the 1969 Chevrolet Truck Data Book;
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.Wrecked 7.2020 after 24 years service.
WorkinLonghorn is offline   Reply With Quote
Old 07-10-2019, 04:27 AM   #27
Dave64
Re: NP435 questions
WorkingLonghorn,
I take it that you lifted that from an early Chevvy/GMC book??
Your illustration calls it the NP435CR (for close ratio???)4.56:1 first gear.
My Chevvy/GMC manual calls it the NP435GA.
So, as yet, still a bit up in the air as to just exactly is the correct designation.
Which makes it a bit hard to positively identify it by designation alone, that's why I thought it would help by adding as much info from the parts manual as I could, pertaining to the actual input shaft dimensions.
A bloke sold me an original Australian parts manual for a C30, but it only has the 3 speed column shift, the SM465 4 speed or the auto, none of which is really applicable to what I am after. This bloke also added that prior to 1969, Chevvy trucks were assembled in Australia from imported components, wasn't until the next change of body style(1972???) that GM started stamping their own firewalls etc (for R/H drive) over here also. Which only confuses the issue more. When I asked this bloke if they could be identified by engine, he also said that the C10/20/30 came out in Australia with 283/307 V8's as well as the 350's, but he ran larger C50 and C60 trucks that ONLY came out with the 292 BIG SIX engines, even though some had the 5 speed boxes and some with 2 speed diffs. All of which is not helping me much as seem to be getting further and further away from the NP435's.
It also seems that you cannot line up year to year models between yours and ours, we always seemed to be 12-18 months behind you guys.
Dave64
Dave64 is offline   Reply With Quote
Old 07-10-2019, 02:43 PM   #28
weim55
Re: NP435 questions
Is that 435 box you have an original out of a Chevrolet or GMC Or are you converting a box from another make to fit your Chevrolet or GMC?
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 07-10-2019, 05:28 PM   #29
WorkinLonghorn
Re: NP435 questions
Dave, yeah that info is from the original "Chevrolet Truck" "Data Book" that was for the dealers. Has nearly every option and spec for these trucks by year.
Somebody this past week posted a GMC original part catalog for sale and it sold apparently. You could look over the posts for the last week and find the guy that bought it and ask him to look up the part number for that shaft and housing, if that would help your search any.
Old 07-10-2019, 06:18 PM   #30
kwmech
Re: NP435 questions
I have a complete one out of a 1968 GMC
Old 07-10-2019, 09:57 PM   #31
Dave64
Re: NP435 questions
Hi Guys,
Thanks for the replies.
kwmech,
Thanks. Rather than buying another complete box and all the associated drama of getting it sent halfway around the world, that is why I'm trying to get hold of just the correct input shaft (and input shaft housing, if obtainable).
WorkingLonghorn,
I'll see if I can find the relevant posting and shoot off a private email.
Steve,
It's not the ORIGINAL Chev/GMC box, but am trying to get it into a 75 C30 with a SBC350.
Don't know if you blokes are familiar with these NP435's, but I have two boxes here that I have successfully converted. One is a Dodge version with an International Harvester input shaft, behind a Perkins 203 TDI in one project, the other is a Ford NP435 with a Dodge 23 spline fine input shaft.
It is NOT the bellhousing that is the problem, have a late model bell that has the two extra ears machined into the front face, so will accept the SBC350 block.
Good thing about all the variations is that although the input shafts and actual case configurations are slightly different, the actual internals are mostly interchangeable (except for the mainshafts). I have, as I said, picked the eyes out of the ones I have here and made up two complete boxes to suit my applications.
Reason I'm trying to run an NP435 behind the 350, is the close ratio version , for what I want, is a lot better suited than the deep granny gear.
As I have said, I have had about half a dozen of these boxes in differing guises at one stage or another, still got enough parts left over to make one more good one, IF I can get the right input shaft.
If I can simplify it that way, can use just about standard Chev/GMC parts, already been down the track matching clutch, throwout bearings etc on the Perkins project, had to end up getting a special clutch disc made up from scratch.
Thanks again for all your help, Cheers Dave64
Old 07-10-2019, 10:02 PM   #32
factorystock
factorystock's Avatar
Re: NP435 questions
Chevy called it NP435CR, GMC called it NP435GA, same trans.
factorystock is offline   Reply With Quote
Old 07-10-2019, 10:19 PM   #33
Dave64
Re: NP435 questions
kwmech,
Any chance that it is somewhere that you may be able to find any marking numbers on the input shaft bearing housing?
Most of these NP boxes had casting numbers either on the face or around the rim of the four bolts that hold the shaft housing to the actual transmission face.
Sometimes possible to seperate just who the boxes were built for by casting numbers.
Any help appreciated, Dave64
Old 07-10-2019, 10:33 PM   #34
Dave64
Re: NP435 questions
factorystock,
Thanks, that clears that up!
Cheers, Dave64
Old 07-10-2019, 11:37 PM   #35
WorkinLonghorn
Re: NP435 questions
These guys might have what you need. Also their site shows exactly which year of each model had the taper and which had the ball bearings. Give them a call.
http://old.drivetrain.com/parts_cata...rhaul_kit.html
Old 07-11-2019, 04:55 AM   #36
Dave64
Re: NP435 questions
Thanks. All.
Dave64
Old 07-11-2019, 08:04 PM   #37
kwmech
Re: NP435 questions
Tag on my trans reads
3928126 CA 7 B
11 17 67 435
Old 07-11-2019, 09:29 PM   #38
Dave64
Re: NP435 questions
Thanks,
Sent an email to that site posted, received a message to say they have received it and are looking into it.
Will also chase up that tag number and see what it reveals.
Dave64
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
