07-09-2019, 12:37 PM | #1 |
Patina protection
Hello everyone. Just checking to see what anybody has done or any suggestions to preserve the patina on my truck. I use wizards detailing spray on it now and works great but I was looking for something that doesn’t wear off as fast. I don’t want a gloss look and I don’t want to clear coat it either. Thanks for any input.
07-09-2019, 12:49 PM | #2 |
Re: Patina protection
How about ..... nothing. Other than taking steps to make sure there isn’t excessive deterioration from the elements , ie: make it a Fairweather driver, stay away from mag chloride, salt, sun etc..... even a simple carport makes all the difference in the world. I’m one of those people that anything topical on the paint does nothing but create more wear and, frankly, makes good natural worn paint look really crappy........
Steve weim55 Colorado |
07-09-2019, 05:02 PM | #3 |
WOW!! Where did you find that beauty? Looks like what you are doing works. I use a ton of detail spray on mine. As a matter of fact I have never washed it after I got it painted. Been five years. No ware on the paint that I can see.
07-09-2019, 07:47 PM | #4 |
Boiled linseed oil. Hood been out in the weather since April. Our grandfathers used it to protect saws and other hand implements.
07-09-2019, 10:25 PM | #5 |
Another vote for Boiled Linsead Oil .
07-09-2019, 10:56 PM | #6 |
What brand of wheels are those? Thanks in advance
07-10-2019, 10:10 AM | #7 |
I knew a cheap old timer who would rub used transmission fluid onto his junkers. He did it as a cheap (used trans fluid is usually free) way of making them shine but I’m sure it protected them a bit too.
1967 C10 LWB 250 6cyl 3ott Panaramic cab “Layla” 1967 Camaro 327 ‘glide cruiser “Bailey” |
07-10-2019, 12:12 PM | #8 | |
07-10-2019, 12:14 PM | #9 |
Thank you! I bought this from the original owner (kind of) in Montana. He used it around his ranch.
07-10-2019, 12:15 PM | #10 |
07-10-2019, 02:18 PM | #11 |
I say nothing... i get the same questions all the time... it's taken 51 years to look like this... Mine doesn't sit outside, and i take better care of it than it was it's first 51 years of life... all i did to mine was dawn dish soap and scotch brite to remove oxidation...
https://www.ebay.com/itm/295742064443 |
07-11-2019, 08:32 AM | #12 |
Mop & Glo floor wax. Wipe it on with a cloth - its acrylic so it holds op pretty well and has a satin shine. When it wears off you you simply reapply.
07-11-2019, 10:01 AM | #13 |
Paint , Paint is really good protection , and you could drive it in the rain . All these oils / floor wax ? / transmission fluid , semi gloss shiny stuff just seems to me that it will contaminate the surface and every crack and crevice. When you or the next owner decide to restore the truck years from now it will have to go all the way to bare metal .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
07-11-2019, 10:53 AM | #14 |
Agree but anybody doing a proper paint job is going to take it to metal anyway.
Those wanting to preserve a patina should either leave it completely alone or protect it. If you want to protect it then a satin clear over it is best assuming you get a good bite but that can't be assured and I've seen many instances where the clear failed and started to lift. Something temporary like linseed oil or floor wax are better because they are temporary and require re-applying without disturbing the patina. |
07-11-2019, 12:09 PM | #15 | |
07-11-2019, 12:12 PM | #16 |
I appreciate everyone’s response and suggestions to my post by the way. Thank you and keep em coming. Seems like a good topic!
07-11-2019, 05:30 PM | #17 | |
07-11-2019, 10:14 PM | #18 |
I used boiled linseed oil once. About 3 days later I could not even tell I did anything beside collect a lot of dust. Maby it would be better if I could park inside. But I think the dust would still be a problem
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
07-12-2019, 12:41 AM | #19 |
I have a 68 c10 with almost identical wear ...Sorry, I mean "patina"
I use a radical method to protect whats left of my paint. I wash it with soap and water when ever it gets dirty Then, I wax it, and take the buffer to it. 2 or 3 times a year That's it. Cleans up pretty good. Has a natural satin sheen when its done. |
07-12-2019, 01:54 PM | #20 |
I believe there's a number of things that will keep any nasty rust from forming, and allow it to keep looking the same. Several companies make spray waxes, or some call it "detailer" . I don't know how long it would last, wouldn't cost much to try a couple. Zep ,makes a cleaner called, Powerhouse. It cleans and may even protect for a while, great stuff!!!
