04-21-2018, 01:56 PM | #576 |
hillbilly
Re: What did you do to your truck today part IV
Hey i like those speaker enclosures. Do you have more detail about how you made them? What did you do to seal them from the backside? Thanks
-1962 C-10 |
04-21-2018, 03:09 PM | #577 |
Front clip off in order to tidy some things up before the engine goes back in..
Knew it was a solid truck, but great to see just how clean it really is! Always annoyed me how the PO shot a load of black paint around the windshield and under the hood, so I've started rubbing it back wherever I can. Long, slow, painful process.. Looking better already..
Barney, in the UK 1962 Chevy C20 1974 Ford Econoline 1987 Peugeot 205 GTi 1991 Peugeot 205 GTi |
04-21-2018, 11:55 PM | #578 |
I installed my speakers today. I was going you try and get some interior quotes this week but instead I need to figure out why my truck won’t start when it is hot.
04-22-2018, 12:01 AM | #579 |
Is it your starter getting hot?
04-22-2018, 12:02 AM | #580 |
Mine did that when i had headers. I got a mimi starter Works good.
04-22-2018, 12:13 AM | #581 |
04-22-2018, 11:58 AM | #582 |
Picked up an original 63 fender yesterday, and installed it this morning. Looks so much better than the old one that was so rusted out that I had to zip tie the bottom part on.
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
04-22-2018, 05:14 PM | #583 |
I did a little peaking around today and noticed that my fule line is about half an inch from one of my header tubes. It is a braided stainless line. Could that be the problem? Could that cause vapor lock? Does my problem sound like vapor lock is an issue?
04-24-2018, 09:08 PM | #584 |
I did some metal rust repair.
04-24-2018, 09:12 PM | #585 |
04-25-2018, 10:09 AM | #586 |
04-28-2018, 07:46 PM | #587 |
installed my passenger side power window switch now I need to tackle the driver side
04-29-2018, 05:28 PM | #588 |
Doing a little spring cleaning. Rolled out the '66 to watch the action.
Romans 10:9 - The Truth |
04-29-2018, 06:43 PM | #589 |
I got my motor rebuilt.
05-01-2018, 11:39 AM | #590 |
I finished installing the seats. Had to put some 1 1/2 x 1/4" flat iron under the floor between the bolts to prevent breaking of the sheet metal. It stiffened it up a lot.
05-01-2018, 07:03 PM | #591 |
05-01-2018, 10:00 PM | #592 |
I bought a bunch of stuff!
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
05-01-2018, 10:00 PM | #593 |
Looks great!
05-02-2018, 09:39 AM | #594 |
I got my front end alignment done yesterday and man is it nice. I learned something tho so I thought I'd share. The truck pulled to the right. The tire guys said radials will have a tendency to pull one way or the other, even brand new. Their balancer measures how much pull and direction for each tire and recommends a placement to minimize the net pull or to have a slight left pull to accommodate the road crown.
05-02-2018, 09:41 AM | #595 |
A proper job dropping the shop truck.
05-06-2018, 05:27 PM | #596 |
Got the firewall and grill surround painted,going through the heater box repainting and cleaning it up inside.
05-06-2018, 05:52 PM | #597 |
hillbilly
Bought some 05 silverado seats.
-1962 C-10 |
05-08-2018, 12:02 AM | #598 |
Trying to keep the oil in the 250. Tightened down two loose bolts on the valve cover and changed a side cover gasket. Will have to remember to get another #1 (short) spark plug wire next time at the auto wreckers.
05-08-2018, 10:30 AM | #599 |
Finished the drop.
the rear leaf springs had been re-arched about 10 years ago and I had dropped spindles (2 1/2" ) with Eibach 1" under springs before this weekend. But I decided to do the C Notch and had to do several additional steps 1. I had to remove and lower the front spring perch 2 inches I built a gusset and boxed it for strength 2.cut off and remounted spring perch on rear end after setting proper pinion angle. Also had to notch the forward cross member for drive shaft clearance, (no picture as I did this after assembly when we noticed contact during the first test drive) So we put it all together and took a picture for comparison before the C Notch and spring flip After Once we had that all done I just did not like how flat the truck was, it measured zero pitch but looked nose high So back on the lift and I yanked the front springs and pulled half a coil of height out of them by heating and flattening them out Done |
05-08-2018, 10:45 AM | #600 | |
But Found Her 25yrs Later!
