Old 05-23-2018, 11:00 AM   #1
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
rear brackets on 2nd row
Can anyone tell me if the rear brackets on the second row full size seat and the rear brackets on the 3/4 second row are the same brackets?
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 05-23-2018, 03:21 PM   #2
52napco
Re: rear brackets on 2nd row
The rear 3rd seat brackets are shorter
52napco is offline   Reply With Quote
Old 05-23-2018, 03:42 PM   #3
Killer Bee
Killer Bee's Avatar
I think he's talking about the rear brackets on the full width center seat vs the 3/4 width center seat..
as far as I can tell the brackets are similar, but there seems to be right and left corners..
this would obviously affect hole locations so please don't quote my seat install as factory but something to get thread going..
keep bumping this, someone with both factory setups will share the answer with us..
good luck!
Old 05-23-2018, 04:35 PM   #4
richard2717
Equal opportunity joke ofender
richard2717's Avatar
All 2nd row brackets I have encountered have been the same regardless if it was 48" or 60" seat. the tubular brackets on the front of the seat are roughly 7" tall and the rear stamped brackets are roughly 2" tall. As Killer Bee stated there are left and right brackets.
The 3rd row is 4" tall front and rear.
So to answer your question yes the brackets fit either seat.
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 05-23-2018, 09:35 PM   #5
HO455
HO455's Avatar
Did you check the Burban seat sticky above?
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
Old 05-24-2018, 02:07 PM   #6
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Thanks that is the conclusion of have come to as well. It appears the 3/4 seat has four brackets on the rear and the full size only has two on the outside. I am trying to now figure out how the seat belts mount on the full size seat without inner brackets like the 3/4 seat.
Old 05-24-2018, 02:23 PM   #7
richard2717
They bolt directly to the floor. Let me see if I can find my pics
Members I have met.
Old 05-24-2018, 02:26 PM   #8
richard2717
This pic is 3rd row but was same as the 2nd row as far as the middle belt attachments. The belts have a longer tapered boot to them
Members I have met.
Old 05-24-2018, 02:55 PM   #9
Killer Bee
Killer Bee's Avatar
not sure that's correct regarding the number of rear brackets on the full width 2nd row seat..
maybe the bracket configuration changed through different model years?
I'm not entirely sure about the handing of the brackets in mine, but both of my full width 2nd row seats have four brackets..
just peaked under the tarp for a quick pic of this one, only difference between it and the one in my 71 is the right side bracket..
the 71 above with both full benches installed is fairly unmolested, highly doubt either seat has been changed..
my 3/4 3rd row in my 72 only has two corner brackets as Richard pictured above..
Old 05-24-2018, 02:59 PM   #10
richard2717
My 72 plain jane burb I just parted had full width 2nd row and only had 2 rear brackets. Belts were bolt to floor in the middle. I am not sure if it was a year difference or plant difference. As with the 3rd row seats there seems to be no rhyme or reason.
Members I have met.
Old 05-24-2018, 03:00 PM   #11
richard2717
But the yellow 72 I parted had 4 rear brackets. Makes ya scratch your head.
Members I have met.
Old 05-24-2018, 03:09 PM   #12
Killer Bee
Killer Bee's Avatar
maybe someone started parting the plain jane before you did
seems like a full width seat for three adults would need some support in the middle??
either way, if the op is crafting a suburban back together, and the brackets line up with the seat and the floor attachments, I'd run 'em!
the brackets will accommodate the typical seat belt attachments which may also be a plus..
I like stock as much as the next guy, but I am seriously considering rear facing that 3rd row in my 71 and keeping the 2nd row full width..
only concerns are safety and I was hoping to utilize all six shoulder belts..
still researching, but thinking of doing this;
for these guys
Old 05-24-2018, 04:12 PM   #13
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
My full size second row does not have provisions for 4bracketsso I will just bolt the seat belts to the floor. Sometimes the simplest solution is overlooked. Thanks
Old 05-25-2018, 01:34 PM   #14
HO455
HO455's Avatar
My 67 plain Jane full width second row seat only has two seat brackets and the belts bolt directly down to the floor with no boots.
RIP Bob Parks.
