03-12-2007, 02:10 AM | #1 |
chevy truck fan
rear piller bolt size ???
all,
i am hoping that this is a easy question. i am needing to know what the bolt size is & threads for the seatbelt bolt hole that is located in the rear piller behind the seat??? (for use with a 3 point seat belt.) i think it typically has a plastice cover over it. it is the hole in the upper part of the piller... thanks!!!! rodstored-72 |
03-12-2007, 08:24 AM | #2 |
Re: rear piller bolt size ???
The weld nut in the upper part of the pillar is threaded 7/16" x 20, NF thread.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
03-12-2007, 10:12 AM | #3 |
chevy truck fan
jim
thank you!! for your time in answering my question, that is exactly what i needed to know... p.s.: just out of curiosity how did you come about that very important knowledge??? if you don't mind sharing... thanks again! rodstored-72 |
03-12-2007, 08:10 PM | #4 |
I installed shoulder belts in my son's 71 C-10 and needed the bolts for the upper mount. I had some left over seat belt bolts with the 7/16 fine thread which fit the holes perfectly.
Jim
03-13-2007, 10:58 AM | #5 |
chevy truck fan
jim,
thanks again!! i hope i don't bother you too much with the questions.. what seatbelts did you use in your son's truck?? i have purchased a set from a mid '90's suburban.. do you think that they should work ok?? thanks again!! rodstored-72 |
03-13-2007, 07:26 PM | #6 |
I used a set out of a 93 S-10. I really don't know if the belts you are looking at will work. Maybe someone else will post the answer.
Jim
03-14-2007, 10:25 AM | #7 |
chevy truck fan
jim,
thanks! i am going to try to get them to work. the length is there i just neeed to get the base for each side to fit better on the floor. they are a little chewed up though. what made you use the s-10 belts?i would think that they would be too short? also how did the belts fit on the base in relation to te cab floor?? thanks again!! rodstored-72 |
07-29-2012, 02:34 PM | #8 |
chevy truck fan
well i dont know what happen, but i tried to put the bolts in ( 7/16" x 20, NF thread) and they do not fit (thread part) is it possible that the threads are different on my truck??? i don't know if the bolts are ""nf thread"" though.....
any help would be greatly appreciate!!! thanks, |
07-29-2012, 03:00 PM | #9 |
Moderator
Wow...you just got around to this 5 years later?
7/16 20 (fine thread) is the correct size bolt for the pillar in all 67-72 trucks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
07-29-2012, 06:24 PM | #10 | |
chevy truck fan
thanks!! |
07-29-2012, 06:36 PM | #11 |
member #16
7/16-20NF = national fine which is 20 threads per inch on a 7/16 bolt.. You will be better off if you can find 7/16-20 seat belt bolts because they are a shoulder bolt. Those holes would be hard to repair if you "wrench" the wrong bolts in.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
07-29-2012, 11:02 PM | #12 |
chevy truck fan
john, how would i go about finding these seatbelt bolts????
thanks!!! |
