Old 11-13-2009, 12:02 AM   #1
jess66chevy
jess66chevy's Avatar
Lets see your gauge panel!
Here is my gauge panel that I made. I kept the original speedometer and used a piece of sheet metal to cover what I didnt want. Then I went had a sticker made for the speedo numbers. I also use arcrylic for the lens that I bought at home depot.
jess66chevy is offline   Reply With Quote
Old 11-13-2009, 08:19 PM   #2
WILDSTANGRACING
WILDSTANGRACING's Avatar
Re: Lets see your gauge panel!
heres a couple
JUST ASK
WILDSTANGRACING is offline   Reply With Quote
Old 11-14-2009, 09:57 AM   #3
tomlamb
tomlamb is offline   Reply With Quote
Old 11-14-2009, 02:16 PM   #4
Bazooka
Keepin it old school
Bazooka's Avatar
Bazooka is offline   Reply With Quote
Old 11-14-2009, 04:21 PM   #5
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
I dont have pics of mine, but it will be made just like Bazookas
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 11-14-2009, 04:37 PM   #6
dlisabeth
Has anyone come up with a good way to fill or hide the holes in the frame for the switches and ignition, etc... that aren't being used any more? I would like to do this and maintain the horizontal line detail if possible. I am going to set mine up like wildstangracing's dash
dlisabeth is offline   Reply With Quote
Old 11-14-2009, 06:20 PM   #7
ruffrida2005
I need to know the same thing dlisabeth. I thought about filling it with kittyhair.
Paul
Old 11-14-2009, 06:30 PM   #8
protrash64
Resistance is Futile
protrash64's Avatar
Use a glove box door.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 11-14-2009, 07:22 PM   #9
Vernski
Here's one for a GMC I painted the back ground satin black and it looks a little better but I'm still not satisfied, I found some engine turned alunimun sheet stock at www.speedwaymotors.com Part # 911-39520-24 6x24" .063 thick so it shouldn't be to hard ti cut out in the stock configuration as back ground. The stock bezel on these are plastic, does any one know of any where that you could get the plastic chrome plated again there must be somebody doing this somewhere don't you think? I do like the stock configuration with the exception of the idiot lights I may get some smaller jewel faceted lights instead and put in there place. Anybody have anymore ideas for ?---Vernski
Vernski is offline   Reply With Quote
Old 11-14-2009, 07:36 PM   #10
Hilandr451
Hilandr451's Avatar
before
after
Greg Smith a.k.a. "The Highlander"
1966 C20 Custom Camper, 2017 Chevy Silverado 1500
Highlander's Project Pics
Highlander's web site: www.6066ChevyTrucks.com
Hilandr451 is offline   Reply With Quote
Old 11-14-2009, 09:24 PM   #11
198plus
198plus's Avatar
Nice job......Did you do it yourself.
Originally Posted by Hilandr451 View Post
before
after
198plus is offline   Reply With Quote
Old 11-14-2009, 09:47 PM   #12
ruffrida2005
That looks good.
Thanks for the Idea Protrash
Paul
Old 11-14-2009, 10:02 PM   #13
jbgroby
jbgroby's Avatar
Here be mine, the stock look before and the custom made insert with analog dial after (I do not like idiot lights) I simply took the natural layout and replace the lights with gauges. The tach and Clock are GMC OEM pieces and work great.
jbgroby is offline   Reply With Quote
Old 11-15-2009, 01:05 AM   #14
jess66chevy
QUESTION:
Does the GMC gauge cluster fit into a chevy? I like how the GMC has the round individual gauges.
Old 11-15-2009, 01:25 AM   #15
Captainfab
60-66 Nut
No they are specific to the GMC's
You could have the same look with aftermarket gauges......
Originally Posted by jess66chevy View Post
QUESTION:
Old 11-15-2009, 01:44 AM   #16
SCOTI
SCOTI's Avatar
Dash shaped different or????
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-15-2009, 01:54 AM   #17
LILRED66
LILRED66's Avatar
Here are a few of a cluster I have in my '66 Chevy C20 Custom Camper. It is heading to a fellow member this week.
LILRED66 is offline   Reply With Quote
Old 11-15-2009, 01:57 AM   #18
SCOTI
SCOTI's Avatar
What does it take to swap that cluster in where idiot lights were?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-15-2009, 02:03 AM   #19
LILRED66
LILRED66's Avatar
In the 4-5-6 Chevy trucks, the only part that is the same on the gauge cluster and warner light cluster, is the bezel, so it is better to find a gauge cluster, instead of trying to modify a warning light cluster.
Old 11-15-2009, 02:06 AM   #20
SCOTI
SCOTI's Avatar
I guess I should re-phrase the question . . .... If I have a 'warning-light cluster' & wish to upgrade to a factory style 'gauge cluster', what do I need to do?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-16-2009, 01:18 AM   #21
Captainfab
60-66 Nut
Basically yes. The GMC gauge panel is longer and I believe narrower that a 64-5-6 Chevy gauge panel. Plus the GMC's still had the switches in the dash below the gauge panel, similar to the '60-'63 Chevy's
In addition to the gauge panel, you will need the wire harness that connects the panel to the connector that is attached to the pedal bracket under the dash. The oil pressure is a mechanical gauge, so you will need to run a line for that. And of course you will need the correct sending unit for the H2O temp. I believe that is all that is needed.
Old 11-16-2009, 02:18 AM   #22
DaddyMack
Wide Eyed User
DaddyMack's Avatar
does this count ? lol
more current... like last friday..lol
1962 Chevy P/U SB Fleetside
350/350
2.5/5 static drop
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723
Final (as final can be ) Pics: http://67-72chevytrucks.com/vboard/s...d.php?t=393441
DaddyMack is offline   Reply With Quote
Old 11-16-2009, 10:37 AM   #23
98L150
///Relaxed Atmosphere
98L150's Avatar
here are my mooneye gauges im putting in my 64
72 Suburban
64 Chevy short fleet
04 Chevy Colorado Sport Reg Cab
2012 Chevy Avalanche
2003 Chevy S10 Blazer Xtreme
http://www.hubgarage.com/mygarage/RA_Jeff
64 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=295915
98L150 is offline   Reply With Quote
Old 11-16-2009, 05:50 PM   #24
ol Curt
Junior Member
ol Curt's Avatar
This is fairly accurate... http://rmcavoy.freeshell.org/Truck_gauges.html
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 02-15-2016, 02:23 PM   #25
harrison56
here b my gauges
harrison56 is offline   Reply With Quote
