Old 10-12-2018, 07:18 PM   #1
jcondo
whats my front axle?
I was told my front axle is a corperate GM, but the parts store is telling me its a dana, when I asked for the cover gasket.
these are the photos I was able to get.
jcondo is offline   Reply With Quote
Old 10-12-2018, 07:27 PM   #2
mongocanfly
mongocanfly's Avatar
Re: whats my front axle?
The corp 10 will have the ears at the bottom of the diff....Dana does not...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-12-2018, 07:29 PM   #3
jcondo
ears on the front axle too? i have only seen them on the rear.
Thanks for the info
Old 10-12-2018, 08:45 PM   #4
sweetk30
sweetk30's Avatar
dana covers all have the same shape just get bigger .
corp 10 bolt have ear's on the bottom . and a rounded cover shape over the dana shape style .
corp didnt use the gear ratio tags on the 1 bolt for the cover like dana did unless rusted off or left off in a past service .
also the 1 pic shows 44-?? cast in the 1 web = dana 44 model center section .
skip the gasket and grab a tube or ultra black rtv . same basic price / instock / works better . i have a dana 60 now that leaks oil with a brand new spicer gasket on it and both surfaces were 100% clean and flat .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 10-12-2018, 09:22 PM   #5
GSP7
GSP7's Avatar
look like a Dana
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is online now   Reply With Quote
Old 10-12-2018, 11:52 PM   #6
B. W.
B. W.'s Avatar
Dana 44
B. W. is offline   Reply With Quote
Old 10-13-2018, 01:41 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
If you decide to use a gasket sealer, I'd recommend Permatex 81182. It's made specifically for use with gear oil.
You can use it in lieu of a gasket, but I prefer to use a thin coat on both sides of a gasket.
I've had leaks with other stuff but no leaks using this.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 10-13-2018, 02:18 PM   #8
Killer Bee
Killer Bee's Avatar
make model and year would usually be more helpful in determining axle identification, but this one sure looks like a Dana..
here's some other posts with pictures, dimensions, and other tells to help identify exactly what it is..
to paraphrase, the Dana case model is cast in one of the corners and the gear ratio is stamped on a tag..
good luck!
http://67-72chevytrucks.com/vboard/s...48&postcount=8
http://67-72chevytrucks.com/vboard/s...75&postcount=6
Old 10-14-2018, 02:03 AM   #9
kwmech
That is a Dana cover
Old 10-14-2018, 11:08 AM   #10
Jeff's bowtie's
It's a Dana 44 look on the 4th pic you can see 44F all Dana rears are stamped like that to identify them as to what model they are
Jeff's bowtie's is offline   Reply With Quote
Old 10-14-2018, 10:06 PM   #11
jcondo
Thanks everyone for the replies.
It is stamped 44-8F, but the gasket they ordered for me is not correct so I ended up just using a permatex gasket sealant. Hopefully it doesn't leak.
As far as the year, make, and model. Its a 1977 Chevrolet K10, which if im correct is the first year of the Corporate GM front end. The P.O. said it was a corporate Gm, that's why I was asking.
Thanks again everyone.
Old 10-15-2018, 12:01 AM   #12
Jeff's bowtie's
It could be confusing as both Corp 10 bolt and Dana 44 have a 10 bolt cover
