10-02-2018, 06:09 AM | #1 |
1972 Chevy Blazer Ignition Switch Smoking
So I have a problem. Just picked up 72 blazer with stick 350 and has the gauge cluster no tach, not the idiot light cluster. My temp gauge and my ammeter gauge currently do not work. Everything else works fine. I’ve spent the last 2 weekends troubleshooting the 2 gauges and am striking out!
For my temp gauge, my dark green wire goes from gauge cluster harness connector all the way to the temp sensor sending unit on the cylinder block as it should. Replaced the sending unit and still doesn’t work? For my ammeter gauge, there is a black wire and a black/white wire that both run from the gauge cluster harness connector to the engin compartment. The black/white wire connects to the red wire running to the battery and has a soldered in-line 4 amp fuse. The fuse is good. The black wire runs to the positive battery terminal. My ammeter gauge stays smack dab in the middle and doesn’t move, even with the battery disconnected? The 3rd problem I have is tonight when I get as laying on the floorboard and looking up under the dash, I was turning the key on and noticed smoke bellowing out of my key ignition switch housing! So, I disconnected the battery and removed my key ignition switch and took it apart to see what the smoke was coming from. It looks like the metal leg that the ACC (Big brown wire and little brown with white wire) and the SOL (big purple wire) connect to melted in half? What would cause this?? Any help would be much appreciated!! Here are pictures: |
10-03-2018, 02:47 AM | #2 |
Re: 1972 Chevy Blazer Ignition Switch Smoking
OK, so I really need some help here... I'm hoping someone will reply to my post soon with some solid advise... I sketched a drawing with color showing my current wiring setup for my ignition system. From what I can decipher, my wiring is correct? I do have one question though on my current setup?? I noticed that the PURPLE wire running from the "S" position on the starter solenoid to the "SOL" position in the ignition switch is not showing up on any electrical diagrams I have come across? Is this proper for my setup or is it wrong? I appreciate any feedback you can give!!
10-03-2018, 11:00 AM | #3 |
I had this problem before with a newer harness but the original ignition switch. I just bought a new switch and no problems since. The purple wire does go from the S terminal to the SOL on the switch but, normally goes thru the fuse panel with in its travel. Does yours? Based on your picture it doesn't...
10-03-2018, 01:36 PM | #4 |
wiring diagrams...http://67-72chevytrucks.com/vboard/s...d.php?t=185856
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
10-04-2018, 01:47 AM | #5 |
Sorry 6768chevylover!! My artist skills are sub-par, and it took a lot for me to even post that drawing ... My drawing is incorrect only for the large purple going from SOL on ignition switch to the S on the starter solenoid. It actually does go through the bulkhead connector on the firewall and into the engine bay like it should. See the picture attached. Thank you for your input. I'm wondering if it was just a coincidence in timing that I was investigation my electrical under the dash at the same time my ignition switch went out?? I bought a new switch and installed it, just haven't connected battery yet as I'm worried It's gonna fry the new one!!
10-04-2018, 01:50 AM | #6 |
Thanks for the reply A1971Blazer! I have those diagrams already, but I noticed there are some wires that don't match my vehicle's setup?
10-04-2018, 01:58 AM | #7 |
So I have 3 wires that run from a voltage regulator or something above my fuse block inside the cab, and run wrapped together through the firewall into the engine compartment, and are all cut? Does anyone know what they used to run/connect to?? See picture:
10-04-2018, 02:06 AM | #8 |
Here's a picture of the 3 wires that are cut in engine bay. This picture is of the other end of the wires plugged into some sort of regulator or something above the fuse block... Any one know what these used to connect to??
10-04-2018, 02:16 AM | #9 |
Horn relay. Is it bolted to the firewall? Have had trouble with my old wiring in this area, what with the relay getting super hot and melting wires. Still trying to figure it out also.
10-04-2018, 02:20 AM | #10 |
Oh, just noticed your firewall may be fiberglass? Patched or what? Might be a ground problem as it is not attached to a metal surface.
