Old 05-06-2019, 04:09 PM   #1
Second Series
Second Series's Avatar
Front brakes dragging 1988 k2500
1988 K2500 six lug. RWAL brake system. Brakes are dragging on the front. The calipers are new. The master and booster check good. I had to hammer on the calipers to get them into the bracket. Do the calipers need to be free in the bracket? It looks like I need to file the calipers so they have some room to move, but Iím looking for some input here.
1947.2 1 ton Chevy Panel
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
1988 GMC K2500
1990 Chevy K1500
2001 Chevy Tracker ZR2
Second Series is offline   Reply With Quote
Old 05-06-2019, 07:54 PM   #2
mingoman
Re: Front brakes dragging 1988 k2500
I mentioned this in your other post, but I'll throw my thoughts here to make sure you see it.
I'd replace the rubber hose going from the hard line to the caliper. They're known for separating on the inside and letting fluid go to the caliper, but not back very fast. I've had two that I'd swore were the caliper that turned out being the hose.
76/77/78 Cheyenne
1997 K3500 454 soon to be 496
mingoman is offline   Reply With Quote
Old 05-07-2019, 03:03 PM   #3
Second Series
Thanks for the reply! I had read about the hoses going bad, and when I last drove it and the wheels got hot, I cracked open the bleeders. The fluid did not squirt out, so that made me suspect the calipers. Iím not sure if that is a consistent test for bad hoses, one bad hose may act different from another? I think the problem was that I jammed the calipers on the brackets. I have never ground down a caliper to make it fit, just hammer it in place. I havenít done many and this is the first time I noticed a problem. Last night I ground off some so they are free from the bracket. Iíll know for sure if that fixed it when I take it for a drive.
1988 GMC K2500
1990 Chevy K1500
Old 05-07-2019, 04:50 PM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I 2nd the rubber hose replacement. They are cheap and usually the culprit on older trucks.
I had that issue on a 79 Silverado.
Steve
61_FL_Apache is offline   Reply With Quote
Old 05-08-2019, 03:34 PM   #5
Second Series
Is there a test to determine if the hose is the culprit? I had the front end on jack stands, opened the bleeder and had a hard time turning the wheel. That tells me the caliper was jammed, but it doesnít rule out the hose. I thought the test for the hose was that if when you open the line by the master and fluid doesn't squirt out, open the bleeder, fluid squirts out would point to a restriction in the line?
1988 GMC K2500
1990 Chevy K1500
Old 05-08-2019, 07:19 PM   #6
mingoman
May be the caliper. The ones I did would free up when I opened the bleeder.
76/77/78 Cheyenne
Old 05-09-2019, 11:38 AM   #7
Mr_Rich
Mr_Rich's Avatar
The calipers should slide through the bracket freely. That could be part of a problem. My truck will be thirty years old (of ownership too...) and I've replaced the calipers and went with stainless braided brake lines on the front and rear in the last ten to fifteen years myself.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M.
1997 K2500 Chev. EC 7.4L/ 4L80E
Mr_Rich is offline   Reply With Quote
Old 05-09-2019, 11:51 AM   #8
Killer Bee
Killer Bee's Avatar
the 'flapper' hose symptom you mention is not always consistent which can make it difficult to diagnose..
also not always easy to see even while looking through a hydraulic hose, may need some fluid force to make it show its butt..
as already recommended, just replace them anyways if old and suspect, cheap insurance from a brake failure..
as for the calipers, they absolutely have to move freely on the brackets as they are friction release..
if you still have the old ones, fit one in for comparison and you might find your culprit there..
that's a good start, keep us posted and good luck!
Killer Bee is online now   Reply With Quote
Old 05-12-2019, 07:26 AM   #9
Yes. Replace the hose (I'd do both) and see if that fixes it.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC
'67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi..........'The 67' (project)
'72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok...'The 72' (rolling)
R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586
Old 06-05-2019, 01:52 PM   #10
Second Series
I drove the truck on a few errands yesterday and had no problems with the brakes. If the brakes drag again, I'll replace the hoses. I used a sanding disk to grind the calipers, and put some silicon grease on the sliders.
1988 GMC K2500
1990 Chevy K1500
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
