Old 01-30-2024, 06:10 PM   #1
70chevyk20
1970 Chevy k20 front drums
Anyone know if these rear drums part number BrakeBest Select Brake Drum - 9625DGS from a dodge 3/4 ton van fit the front of my 1970 Chevy k20 with Dana 44 open knuckles front axle? I know there was an older thread but I want to make sure they fit good and work before I possibly buy them. Thanks
70chevyk20 is offline   Reply With Quote
Old 01-30-2024, 09:22 PM   #2
IronCanine
I'm trying....
IronCanine's Avatar
Re: 1970 Chevy k20 front drums
I am working toward this. That's what I have bought. If I beat you to it, I'll let you know.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 01-30-2024, 09:44 PM   #3
70chevyk20
Ok thanks let me know if they work out for you then I’ll grab a set thanks.
Old 01-30-2024, 09:58 PM   #4
70chevyk20
If you could also take pictures for me if they fit that would be great thanks.
Old 01-31-2024, 08:33 AM   #5
At my NAPA store I was sent home with the wrong Dana60 shoes twice. I brought my shoes in and the better parts man grabbed a book that had drawings and dimensions or various shoes. For an 8-lug it's all about the diameter and surface width. Your drums should have "max dia" stamped on the back edge. Mine said 12.125", so 12" drums allowing for 1/8" machining
Old 01-31-2024, 08:46 AM   #6
Chaparralman1974
Chaparralman1974's Avatar
I am not sure about the open knuckle dana 44 with drums, but for my closed knuckle dana 44 on my 1967 K20, the Raybestos 2008R drums were a fit. I did have to drill out the lug holes and ream them as I have upgraded the studs to 9/16" but the drums themselves fit over the shoes perfectly. I believe that this drum was used on 1950's Chevy 3/4 tons, but I am not 100%.
https://www.rockauto.com/en/moreinfo...t=1744&jsn=727
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272
Chaparralman1974 is offline   Reply With Quote
Old 01-31-2024, 09:31 AM   #7
70chevyk20
Ok thanks probably won’t work I’m thinking I’ll possibly try the oreillys part number drums and see if they work if not I’ll probably return them.
Old 02-01-2024, 10:39 AM   #8
jerry moss
Born Psycho
jerry moss's Avatar
a place called torque king 4x4 shows them (406)384-0270, they are quite pricey @ $283.98 each
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is online now   Reply With Quote
