Old 12-05-2016, 04:39 PM   #1
c10-72 II
Active Member
c10-72 II's Avatar
2wd conversion front crossmember question
Just picked up this gem for free over the weekend. Actually pretty rust free. I will be converting to 2wd since I already have the front cross member, steering etc from a donor vehicle. YES I've done the whole search button thing and couldn't get my answer. Guys that convert to 2wd, where are you measuring from to get the crossmember lined up correctly? I understand it has to come forward. I heard that one measurement is 20 1/4 inches from core support rivet to crossmember nut. Thanks, Jon
c10-72 II is offline   Reply With Quote
Old 12-05-2016, 05:30 PM   #2
tobiahr
tobiahr's Avatar
Re: 2wd conversion front crossmember question
I used the chassis gauge holes and compared to a original 2wd. An example of the gauge holes here http://www.chuckschevytruckpages.com/framespecs.html
tobiahr is offline   Reply With Quote
Old 12-05-2016, 11:13 PM   #3
c10-72 II
Active Member
c10-72 II's Avatar
Cool, thank you
1972 GMC C2500 Tow Rig project
1972 C10 Air Bag project
1967 C10 Drag Truck project
1967 GMC Patina Special project
1968 C10 I have no clue what to do with project
1969 GMC C6500 I wish I had more money project
1986 K10 I have too many damn projects
Old 12-18-2016, 07:20 AM   #4
montrosepatriot
the bolt holes 4 the bolt-in IFS r pre-drilled in the frame - use the donor parts from a 2WD and line up the holes
montrosepatriot is offline   Reply With Quote
Old 12-18-2016, 08:43 PM   #5
c10-72 II
Active Member
c10-72 II's Avatar
Cool, thank you
