06-03-2018, 10:03 PM | #1 |
building a 49 Chevy 3800 for towing/hauling
I recently inherited this old farm truck. It's a 49 3800 single wheel that used to have a stake bed on it. Since it's already a 1-ton I'm looking to convert it into a hauler that I can haul parts/cars with. The heaviest I'm looking to tow would be my C10 (4000lbs without trailer). I know this truck has probably moved that much weight before, but i'm looking to do it safer and at higher speeds. The speed limits on Texas interstates are 75+mph and I'll get run over going 40-55mph. I've got a pretty good idea of what I want to do for engine, transmission and rear axle. I'm stuck on the front axle and front brakes.
I hate front drums. I know they can stop well, but they require constant adjustment to stop straight. I also know that there aren't really any good ways to convert my front axle (3600 and 3800) to disc. One way is to convert to a 3100 front axle but then I'm using Camaro discs and calipers for towing. That doesn't seem right. Are there any more heavy duty options available? I have a jeep ZJ front dummy axle that I could weld leaf perches onto, but the brakes are no bigger than Camaro brakes. What other considerations should I be taking? I'm open to ideas. Right now I'm in the early planning stages.
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
06-03-2018, 10:27 PM | #2 |
Re: building a 49 Chevy 3800 for towing/hauling
http://americanmusc1e.com/Photos/20180426_123724.jpg
my first attempt at hosting photos on my web server :P
06-04-2018, 12:09 AM | #3 |
60-66 Nut
What I would do is install a '73-'87 C20 or C30 front suspension which already has disc brakes and will be 8 lug. If you must stay with a straight axle and leafs, some of the late '80-'s early '90's C4500's had straight axles. Those trucks have the 19.5" wheels.
06-04-2018, 11:43 AM | #4 |
Post Whore
one down side to using later model truck axles or front suspension is the width...it just doesn't fit well with the narrow 1/2 3/4 &1 ton AD trucks.......if you went with a 4000 or 6000 series truck front clip,they have wider , longer and taller front sheetmetal...
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 06-04-2018 at 11:51 AM. |
06-04-2018, 01:05 PM | #5 |
Long read, but looks to be pretty valuable info...
https://www.stovebolt.com/ubbthreads...25027&page=all |
Thread Tools | |
Display Modes | |
