Old 08-06-2020, 01:49 PM   #1
msg
Vacuum gauge options for a 66?
Ive been looking at different threads like the one below and seen that some of the oldsmobile vacuum gauges can be modified but I have no idea which gauges might be worth looking at that will be compatible.
http://67-72chevytrucks.com/vboard/s...ch#post4818388
Anyone have a few options that they can share? I was going to plan to buy the decal set to redo my cluster and thought I would make use of the left and right spots that are blanks now.
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 08-06-2020, 11:19 PM   #2
jocko
jocko's Avatar
Re: Vacuum gauge options for a 66?
Early 60's Pontiac, Chev, and Olds console tachs are a nice fit. They are often on ebay, but nice condition ones are starting to get a little pricey, but not too bad. Here's one - it's been a little while since I did it, but pretty sure this is what I did my vac gauge conversion with. https://www.ebay.com/itm/60s-Pontiac...wAAOSw3dVfHt~p
Old 08-07-2020, 09:18 AM   #3
msg
Thanks Jocko! Ill do some snooping on ebay for 60 to 67ish I guess year range for all 3. Ive seen some that are for Air vs Vacuum too. I need to learn more on what the air gauge was for.
Old 08-07-2020, 09:23 AM   #4
LT1 Burb
LT1 Burb's Avatar
Here is a Pontiac one I put in my Suburban way back in 2002.
LT1 Burb is offline   Reply With Quote
Old 08-07-2020, 10:27 AM   #5
msg
Looks great! So is $100 about what to expect on a pontiac vacuum gauge?
Interesting tach with the stem, so you set your red line with it I guess?
Old 08-07-2020, 05:27 PM   #6
jocko
jocko's Avatar
Cost of the early 60s GM vac gauges is primarily driven by the condition of the chrome cup housing, so if you can find one that works, but with a crappy housing (which you won't need) you can get a good deal. Doesn't matter if Pontiac, Chev, Olds etc, all have the same guts, just a different types of detached face plates with a mfgr name on it.
Old 08-07-2020, 05:28 PM   #7
jocko
jocko's Avatar
I LIKE that tach.. what's that out of? Looks almost vac-matched!
Old 08-08-2020, 09:22 AM   #8
LT1 Burb
LT1 Burb's Avatar
Same year Pontiac's as vacuum gauges.
Old 08-08-2020, 01:22 PM   #9
msg
Whats the best way to bench test the vacuum gauge before installing it?
Old 08-09-2020, 10:16 AM   #10
LT1 Burb
LT1 Burb's Avatar
suck on it!
Old 08-09-2020, 11:25 PM   #11
jocko
jocko's Avatar
awesome, thank you!
