10-05-2014, 08:18 PM | #1 |
1969 C20 lower ball joint stuck
I'm replacing all the front end hardware as part of my restoration project.
Things have be going well until I went to knock loose the lower ball joints. Even with a pickle fork I can't get them to pop. At this time I'm considering removing steering knuckle and brake backer plate to gain more access. But before I wanted some advice. So please help. |
10-05-2014, 08:22 PM | #2 |
Moderator
Re: 1969 C20 lower ball joint stuck
Loosen the castle nut, leaving it still attached with enough threads so it doesn't come flying off. Use a hand held sledge hammer and smack the spindle HARD. I have never failed to remove one in this manner, it will pop loose. You want the castle nut to keep the spring from flying out when the ball joint pops loose.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
10-05-2014, 08:38 PM | #3 |
Or you could get a ball joint press. Most auto parts stores have or will rent them out
10-05-2014, 08:51 PM | #4 |
Moderator
He is talking about removing the spindle from the ball joint...not the ball joint from the control arm (in which case, yes, it would need to be pressed out)
10-05-2014, 09:06 PM | #5 |
10-05-2014, 09:43 PM | #6 |
I agree that whacking it with a sledge should knock it loose, but I've found a gentler way that works well for me. I make a "spreader" by using the lower shock mount bolt, a 3/4" socket and an oversized socket like a 1 1/16". The oversized one just goes over the top ball joint nut and rests against the spindle. The 3/4" socket sits upside down on top of the loosened bottom ball joint nut. (You might have to use another 3/4" nut as a spacer inside of the lower socket depending on how long the top socket is) Once you have it in position, a few turns with a big 3/4" open end wrench will pop it loose. This is how I ended up getting the original ball joints loose on my '67. You can then reverse it to pop the upper one loose if you need to.
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
10-05-2014, 10:22 PM | #7 |
WOW! A simple press! I will give it a try. Thank you
10-06-2014, 10:33 AM | #8 |
@ NC67Chev: Very clever, I'll have to remember that one.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
10-06-2014, 04:24 PM | #9 |
Thanks for that tip NC67chev.......a simple idea that works well...I like it !
10-06-2014, 10:06 PM | #10 |
Update.
NC67chev..... You rock!!!!! I tried your method using a grade 8 fine thread bolt and to my surprise it worked. There was no hammering, prying or cheater bar needed. A simple 3/4" wrench is all it took!!! However I did oil the threads on the bolt. My only regret was not knowing this trick before I mushroomed my pickle fork. |
10-07-2014, 07:15 AM | #11 | |
10-07-2014, 10:18 AM | #12 | |
The Older Generation
It's known as good old American Ingenuity...... Glad you got it off. LockDoc
10-07-2014, 11:09 AM | #13 |
The sad part was I thought of using a simple press but could figure out a simple implementation.
It took me less than 10 minutes to both sides. Again thanks for sharing! |
07-04-2015, 11:27 AM | #14 | |
Posted via Mobile Device |
07-06-2015, 06:56 PM | #15 |
Have you tried using heat? I couldn't get mine to budge on my 67 until I got it really hot. Still took 5 hits with a big sledge but it finally came loose.
07-10-2015, 11:40 AM | #16 |
Thanks, man. I finally got the bugger loose. Combined simple press, pickle fork, and a bigger hammer. What's that saying? "If at first you don't succeed, get a bigger hammer."
07-10-2015, 12:30 PM | #17 |
Nice work! A bigger hammer never fails
07-10-2015, 01:54 PM | #18 |
Florida Edition
Pickle fork in a air chisel works pretty good also "as seen on TV".
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
09-14-2015, 03:30 AM | #19 | |
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
09-14-2015, 10:37 AM | #20 |
brilliant!. I cannot count the number of times this would have worked for me.
07-12-2020, 08:59 PM | #21 |
Although this is an older post, NC67CHEV's wisdom lives on. . . .
After applying SIGNIFICANT force on my stuck ball joint with a BFH and pickle fork and not being able to break it loose, I found this thread. So I dug out a 3" grade 8 bolt and the right size sockets, put the joint under pressure, hit it once and it popped right away. EXCELLENT advice. Thank you! |
07-12-2020, 10:35 PM | #22 |
This tip has saved me more than once.
07-13-2020, 10:59 AM | #23 | |
Use a torch to heat the stud of the ball joint, then hit it with a hose. The thermal shock from hot to cold will loosen it. |
07-13-2020, 01:08 PM | #24 | |
Post Whore
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
07-13-2020, 01:58 PM | #25 |
