08-05-2020, 12:25 AM | #1 |
Reverse Switch
Bought this: Hurst 366 6809 (Shifter) & 3670006 (Install Kit). Can I use the same reverse switch that is mounted on the transmission or do I need to by a Hurst specific switch for this set-up ?
08-05-2020, 01:08 AM | #2 |
Post Whore
Re: Reverse Switch
Are you referring to the switch for the reverse lights?..does your switch screw into the trans,?if so then you can use the trans switch..no problem..or is it external?
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 08-05-2020 at 12:56 PM. |
08-05-2020, 08:15 AM | #3 |
Re: Reverse Switch
