Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 11-22-2018, 11:57 AM   #1
Steve-W
Steve-W's Avatar
Not starting due to turn signal stick...?
So here's what happened: I was driving along happily when I wanted to open my vent window. Somehow I managed to catch my sleeve on my turn signal stick, which came loose and caused my horn to start blaring. after fiddling with it, the horn went silent and I proceeded without having a turn signal.
came home, shut down the car and the next day nothing. I turned the key, no responds. seeing it's already quite cold here I though it was the battery, so after 20 minutes with starter cables attached to my Audi diesel still nothing.
now I have a new 85Ah battery and stil nothing.
now for the dumb question, I guess it can be only i of 2 things, either the starter relay, of the starter fuse right?. I have an universal ezwire set, installed 4 years ago and threw away the papers.
I guess the big silver relay on the left is the starter one? seeing it says turn on the other? and I can't locate the starter fuse, is that the black box the the upper right of the fusebox?
so I put the turn signal arm back in, but that didn't change a thing.
Feedback is always welcome!
projects:
1969 Chevy C10
1950 GMC 100
1958 Chevy C60 Viking ratrod
Steve-W is offline   Reply With Quote
Old 11-22-2018, 12:13 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Not starting due to turn signal stick...?
Start by checking all the fuses like the horn fuse.
Then check the two small fuses out by the battery. The horn may have blown the 4 amp fuses that are over by the battery. Check for power with a test light at the junction box on the passenger side fender near battery. There is a fuseable link between the battery and junction block it may have blown also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-22-2018, 10:28 PM   #3
El Dorado Jim
sub'd
El Dorado Jim is offline   Reply With Quote
Old 11-23-2018, 10:09 AM   #4
Steve-W
Steve-W's Avatar
Originally Posted by El Dorado Jim View Post
sub'd
? no Idea what that means
projects:
1969 Chevy C10
1950 GMC 100
Old 11-23-2018, 10:16 AM   #5
Steve-W
Steve-W's Avatar
this is an EZwire 12 set, so none of the original wiring was re-used. I don't have fuses near my battery nor do I have a junction box at the passenger side.
I remember that there was a wire called fuseable link, but for the live of me I can't remember from where to where it runs, nor where it would 'break'.
guess I'll have to go through all my wiring, which is a sh*t job, because I neatly wrapped all wiring in shrink wrap.
projects:
1969 Chevy C10
1950 GMC 100
Old 11-23-2018, 02:26 PM   #6
crossfire84
crossfire84's Avatar
It means he is following along to see the end result.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 11-23-2018, 04:48 PM   #7
El Dorado Jim
it means i subscribed to your thread so that i get an email when someone posts an answer to your thread, that way i get to see what others have to say about your issue.
Old 11-23-2018, 04:49 PM   #8
El Dorado Jim
Old 11-23-2018, 05:06 PM   #9
Andy4639
Old member
Andy4639's Avatar
Question Re: Not starting due to turn signal stick...?
Well you have to have power coming into the fuse box before it can go out. I would start by checking the main wires coming to the fuses.
Where is your horn relay and look at it. Something had to blow are the horn would have kept right on blowing.
Old 12-08-2018, 11:58 AM   #10
Steve-W
Steve-W's Avatar
Solved the issue by putting in a by-pass to the starter relay.
I have a starter button now, which is temporary. have to figure out which wire from the ignition is the old fuseable link.
projects:
1969 Chevy C10
1950 GMC 100
