08-10-2017, 09:37 AM | #26 |
Re: Eric's 1966 Turbo 6.0 build
Cool build. Tagging in to follow.
08-10-2017, 10:43 AM | #27 |
Cool build. I'll tag along. I been wanting to do a turbo for quite a while now, but have held off mainly because I never done one and little gunshy.
Keep us posted.
"Life is too short to drive a boring vehicle". Later, Wayne |
11-17-2017, 09:09 PM | #28 |
Back Again. Getting the Exhaust finished before I move on to other stuff. This is the first build I'm having painted so I'm super worried about drilling holes in anything AFTER paint. Going to basically assemble everything and blow it back apart for final paint stuff. Got the Wastegate mounted and Recirculated it into the downpipe.
11-17-2017, 09:10 PM | #29 |
west side. about 10 minutes south of downtown. @Dpowers
11-26-2017, 11:20 PM | #30 | |
This is my Build A 5.3L 1965 C-10 Fleetside http://67-72chevytrucks.com/vboard/s...d.php?t=502100 |
01-07-2018, 05:52 PM | #31 |
Winter is car wash busy season here so the poor truck has been neglected! Lots of bed parts ordered and odds and ends I'll get some pictures of soon. I recently had Rendered Rides work up what I'm going for..and i'm beyond happy with the outcome.
01-08-2018, 03:34 PM | #32 |
Just stumbled across this build, LOVE it! These turbo builds always intrigue me. Probably just going to do an N/A LS in my 64, but DEFINITELY going to build a turbo LS in something down the road! Love the rig so far dude, keep it up
Been a crazy 2018. Moved twice, back HOME in Oregon. Now to put everything back together, including the truck... My build thread for "Rocket" - http://67-72chevytrucks.com/vboard/s...d.php?t=753023 |
01-08-2018, 03:52 PM | #33 |
subscribed
01-15-2018, 11:19 AM | #34 |
Got some time to finish the High Hump install and throttle assembly.
My new favorite things are Riv-nuts! No more welding nuts to stuff! Whole high hump is removable. I also took an S10 throttle bracket and pedal and it fit close to factory ( with some bending). The stock 6.0 throttle cable plugged into the hole in the firewall like it was meant to be there. |
01-15-2018, 04:04 PM | #35 | |
Thanks, this is my first ever turbo anything. So the learning curve is steep. Also the most complete " restoration" as well. Nothing like swinging for the fences.... |
01-15-2018, 07:42 PM | #36 |
Love it. Mine is my first build too. Hoping I dont screw anything up too bad haha. Keep it coming on the pics!
01-23-2018, 12:50 PM | #37 |
what size is the new intercooler?
01-23-2018, 01:15 PM | #38 |
Looking good. I plan to add a turbo once I get mine together and running NA. Subbing.
1965 Chevy C10 SWB Step (Family Restoration Project) http://67-72chevytrucks.com/vboard/s....php?p=6043410 1972 Chevy C10 LWB Fleet (factory auto/l6) http://67-72chevytrucks.com/vboard/s...d.php?t=580342 |
01-23-2018, 01:55 PM | #39 |
Liking where you are going with this...subscribed. Impressive amount of work you had to do on that cab!
02-08-2018, 07:52 PM | #40 |
The weather has been perfect for carwashing! being insanely busy and installing some new equipment has soaked up almost all of my time. I did get my bedsides delivered and the sheet metal work is DONE! Also have my under dash fuse panel installed for the engine harness I'll attach some pictures I have so far, and some carwash pictures because why not.
02-11-2018, 03:15 PM | #41 |
Keep up the good work
03-07-2018, 10:20 AM | #42 |
My budget Home Depot compressor wasn't happy with the start of body work. So I bit the bullet and upgraded. It's safe the say this will be the last time I buy a compressor in my life! 80 gallon 5HP. 25 CFM. PLumbed it into a refrigerated dryer ( my air tools are happy!).
03-07-2018, 10:24 AM | #43 |
I really wanted to do a column shift for my 4l80e. I spent a ton of time calling ididit, flaming river etc to see if it was possible. I got 3 different answers. No, Maybe, And it might, but not shift through all the gears. So i went with a Ratchet B!tch shifter from Kilduff. I think I'm gonna be happy. The left stick shifts like a normal shifter, while the one on the right ratchets one gear at a time.
03-07-2018, 10:27 AM | #44 |
Bed came off and I built a somewhat sketchy stand so I can work on it. Took the truck outside and wire wheeled and sandblasted everything I could on the frame. I sprayed it with SEM rust converter and it's waiting for paint now
03-07-2018, 10:32 AM | #45 |
Mocked up the boyds tank with the A1000 pump. USed some existing holes in the frame, and welded Nuts and washers inside the frame rail. now the tank can be installed or removed from the bottom easily.
03-07-2018, 12:07 PM | #46 |
meowMEOWmeowMEOW
I thought I was the only other person who ever ran a kilduff shifter lol. Boss Kilduff is a trip man, cool guy, but very much an enthusiast-run biz. I like that twin stick model! I've run his Twister shifter for around 5 years and haven't had an issue. Plus no one ever knows what it is.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
03-07-2018, 12:55 PM | #47 |
love the progress so far,nice work!
03-07-2018, 01:05 PM | #48 |
Great progress. I love the Kilduff shifter, I plan to pull the trigger on a lightning rod shifter in the next few weeks.
03-13-2018, 08:55 PM | #49 |
Love the progress your making. I was looking for a new shifter, think I found one. (Maybe like the one you have) I was wondering what in tank fuel pump you are using? Thanks in advance for the info. Have a good night.
04-18-2018, 08:18 AM | #50 | |
Mine is a boyd's ank with an A-1000 pump. I didn't want fueling issues with the turbo. for a NA Ls swap you could get away with way smaller |
