05-11-2018, 05:46 AM | #1 |
Ridler 650
I changed wheels to the Ridler 650 and was worried about the 4.75 inch backspace on the front. I can tell you they look good but I am buzzing the front tires more than i did with the Coys and 5.25 inch backspace. I added the knock off spinners because i did not like the provided center cap and the color did not match. I am looking for a plain smooth chrome center that will push in like the provided cap. I seem to only buzz the driver side as it sits a tad lower than the passenger side for some reason. does anyone know of a way to message the inner fenders? i thought slosh tubz had a mini inner fender but i think they are for the 73-87 only.
1970 Custom Original 400/400 Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi PS PB and cold factory air Early Classic 4.5/6 Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20 Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40 Rear end is original wide 6 lug converted to 5 lug |
05-11-2018, 06:52 AM | #2 |
Re: Ridler 650
Looking good there cowboy.
05-11-2018, 10:15 AM | #3 |
Re: Ridler 650
Looks very nice. I like.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
05-11-2018, 06:57 PM | #4 |
Re: Ridler 650
Oooooo.. I like....
If you could just find something to shim up the spring on the low side... just enough... -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
05-11-2018, 07:56 PM | #5 |
Re: Ridler 650
Look great!
01-18-2019, 11:43 AM | #6 | |
Re: Ridler 650
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
01-19-2019, 06:39 PM | #7 |
Re: Ridler 650
Good looking truck! Wonder if those 20x10's rub on the inner at all? I ordered a set of them with a BS of 5.5, thought I was good until I checked the rear axle. I adjusting the panhard bar to center the rear with the bed and it looks like I'll have about a 1/4" but that's wheel only, no tire.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
01-19-2019, 07:26 PM | #8 | |
Re: Ridler 650
Front tire is 255/40/20. The 4.5 backspace is not perfect. 5 would be perfect. No problems with the front brake hub.
01-19-2019, 07:29 PM | #9 | |
Re: Ridler 650
