Old 08-21-2017, 01:07 PM   #1
tinydb84
tinydb84's Avatar
Transmission Cooler/Water Issue
Hello all,
In finishing up my brother's LS swap on his Nova he got a new fancy aluminum radiator and connected it all up.
He connected one of the tranny cooling lines to the radiator drain instead of the second cooler line. We fired it up and it was leaking water (unrelated area) after a few seconds so we shut it down and noticed it had a ton of pink foam.
I am guessing we filled the trans with a good amount of water. What would be the best way to proceed with cleaning it all out?
Link filled with broken photobucket pics if you are interested: http://www.67-72chevytrucks.com/vboa...d.php?t=727985
David
Instagram: myfabguy
Old 08-21-2017, 02:20 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Transmission Cooler/Water Issue
Prognosis is not good... Here's some reading on it.
Google: "water in my automatic transmission"
https://www.mistertransmission.com/w...-transmission/
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 08-21-2017, 03:31 PM   #3
95 S_Trucker
95 S_Trucker's Avatar
At the minimum, take transmission out and thoroughly clean everything and install new friction discs. If there is water/coolant in it, there is no way to get it all out without disassembly.
95 S_Trucker is offline   Reply With Quote
Old 08-22-2017, 06:53 AM   #4
homemade87
The thing that puzzles me is how was there any fluid return to the trans . If the out side flow of the tranny line was attached to the drain plug there could not have been any return to the trans from the radiator . Now if the return to the trans line was attached , that's a different story . It would suck coolant straight to the trans .
Being there was a lot of pink in the coolant my guess you had the out side attached or you would not have the pink in the coolant and also you would have a floor full of fluid out the trans cooler fitting that was not hooked up .
This may may have saved your trans . If you wanted to be sure drop the pan and if all looks good you got lucky .
homemade87 is offline   Reply With Quote
Old 02-05-2018, 03:10 PM   #5
tinydb84
tinydb84's Avatar
Update:
We flushed the trans like 8 times. It seems to be slipping pretty bad so we chalked it up to a lost (junkyard trans, water in it, over flushed, etc). So we pulled it and my brother was talking to a trans shop and they asked if we hooked up the TCC switch and I realized we didn't...
For you trans guys out there, would not connecting the TCC make it feel like it slips? I don't want to put it back in to find out I need to pull it back out. I know the switch controls lock up but I'm not a trans guy so any help would be appreciated.
David
Instagram: myfabguy
Old 02-05-2018, 04:12 PM   #6
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Need to read this...
And answer this...? Which line got hooked up to radiator drain, the fluid out or the fluid return line? If the remaining line was hooked up to the proper trans cooler fitting in the radiator, then you either got a mess all over the floor, or you just simply filled the radiator with trans fluid. That would mean the return line was sucking air not water...? Right? You either filled the tranny with water, or filled the radiator with tranny fluid, I dont think you could have done both?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 02-05-2018, 04:25 PM   #7
tinydb84
tinydb84's Avatar
I read that link. I assume the trans is fried but was worth flushing it a bunch to give it a shot.
I missed that last post. Both lines were hooked to the radiator. It is an aftermarket aluminum one with a number of fittings (all the same thread). In the excitement to drive it my brother plugged the wrong fitting. It was sucking in water and pumping out fluid into the radiator.
I have been searching and found this thread which answered my most recent question: http://67-72chevytrucks.com/vboard/s...d.php?t=682333
thanks again for the help.
David
Instagram: myfabguy
