Old 02-08-2018, 12:58 PM   #1
CATrucks
3 Spd Overdrive Lockout Stopped Working
Was driving my 65 c10 this morning and was using overdrive, went to park and my lockout seemed jammed or something. Thought I got it working and when I went to drive again I pushed in my lockout knob in and it wont freewheel anymore.. Went under the truck and could see the lockout lever goes all the way back and cable wasnt jammed or anything. Any idea what it could be or how I can fix it? Hop I didnt bust up anything inside when I tried to un jam it.
CATrucks is offline   Reply With Quote
Old 02-13-2018, 05:49 PM   #2
CATrucks
Re: 3 Spd Overdrive Lockout Stopped Working
Bump...
Old 02-13-2018, 06:23 PM   #3
68gmsee
Active Member
68gmsee's Avatar
I'm not familiar with the overdrive you are talking about but it may help get an answer to your question if you mentioned the type of transmission you have.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 02-14-2018, 03:13 PM   #4
61K10
61K10's Avatar
solenoid working?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 02-20-2018, 02:33 PM   #5
CATrucks
I Believe its a Borg Warner 1962. Solenoid is not the issue I dont think. When I push in lockout lever the transmission doesn't freewheel, so I dont even get the chance to turn on solenoid. The way I have it set up is a push lever to engage freewheeling, then a switch to activate solenoid and shift into overdrive.
Old 02-20-2018, 04:02 PM   #6
61K10
61K10's Avatar
Make sure the leaver is not loose (nut is tight) and slipping on the shaft.
1961 chevy K10
