07-17-2017, 04:41 PM | #1 |
Help me! Please
Okay I have a 73 C10 square body short bed when I purchased it it was already lowered it has Western chassis 2.5 inch drop spindles up front and the flip kit in the rear and it's down about maybe 6 or 7 inches in the rear the front was slightly higher than the rear when I looked at the springs they had spring spacers in the springs one of them or two of them were heated really poor wor.... so what I did was I ordered a set of 3 inch drop Springs and a brand new set of nitro drop shocks for the front I had the upper and lower control arm poly bushed with energy suspension bushings I just had it all installed and now the front is sitting even higher than it was before granted the springs that it had were warned and not stiff the new front Springs are definitely stiff and I know they need to settle but it is sitting way too high what could be the problem? If my math is right with a 3 inch drop spring and a 2.5 drop spindle I should be down five and a half inches I'm nowhere near that..... any ideas why I'm not low upfront the only thing I could think of is the bushings are super tight since they're polyurethane or they put the spring on upside down I have no idea I'm just grasping for straws I want to and I guess the only other alternative is to actually cut the spring not what I want to do
07-17-2017, 04:46 PM | #2 |
Re: Help me! Please
Here it is....urgh not the stance im thought it would be
07-17-2017, 05:14 PM | #3 |
Re: Help me! Please
Were the a-arm bushings tightened w/the suspension extended or w/the trucks full weight on the tires?
07-17-2017, 06:15 PM | #4 |
Re: Help me! Please
The upper and lower arms were removed
07-17-2017, 06:18 PM | #5 |
Re: Help me! Please
07-17-2017, 09:29 PM | #6 |
Re: Help me! Please
re read his info . poly bushed . this would not matter . now if it was still rubber that is a good point you posted.
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
07-17-2017, 10:02 PM | #7 |
Re: Help me! Please
My apologies I stand corrected after doing some research on the stock height of a 73 C10 which is about 33 and 1/2 - 34 inches from the ground to the top of the fender well and now I am at just under 29 inches from the floor to the top of the fender so in fact I am down 5 inches I guess I have to cut the spring in order to get down to about 25 inches I think that's where I want to be
07-17-2017, 11:50 PM | #8 |
Diggin The SquareLife
Re: Help me! Please
what size front tire you running
07-18-2017, 01:22 AM | #9 |
Re: Help me! Please
07-18-2017, 09:12 AM | #10 |
Re: Help me! Please
It still matters as poly bushings can also bind. Bushings should be final tightened w/full weight on the suspension. The exception might be Delrin or spherical rod type set-ups.
07-18-2017, 10:58 AM | #11 |
Re: Help me! Please
You maybe possibly correct because they tighten it while the vehicle was in the air not while it was on the ground.... so are you saying I may be able to loosen the upper and lower control arm while the vehicles on the ground and retighten
07-18-2017, 12:07 PM | #12 |
Re: Help me! Please
I know they are 15s but what is the tire size
07-18-2017, 12:33 PM | #13 |
Re: Help me! Please
07-18-2017, 12:43 PM | #14 | |
Re: Help me! Please
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
07-18-2017, 01:16 PM | #15 | |
Re: Help me! Please
Delrin & Spherical type joints have machined specific tolerances thus bind free but I would still even tighten them to yield w/the vehicles weight.
07-18-2017, 01:19 PM | #16 | |
Re: Help me! Please
07-18-2017, 02:37 PM | #17 | |
Re: Help me! Please
07-18-2017, 03:27 PM | #18 | |
Re: Help me! Please
07-18-2017, 03:28 PM | #19 |
Re: Help me! Please
I have two sets of 3 inch drop Springs if I need to cut one then I will
07-18-2017, 03:38 PM | #20 | |
Re: Help me! Please
If you have to cut aftermarket drop coils, you don't have the right springs. If you still choose to cut them, I would not cut more than 1-coil.
07-18-2017, 04:12 PM | #21 | |
Re: Help me! Please
07-18-2017, 04:46 PM | #22 | |
Re: Help me! Please
Loosen the hardware. Open the hood. Stand on the front bumper while holding onto the front edge of the hood for balance & give it H#@L. Get some movement going. Re-check the dimensions. Re-tighten hardware w/the suspension compressed.
07-18-2017, 06:06 PM | #23 |
Re: Help me! Please
Yes I'm going to try that tactic along with driving it off the curb but I think the first thing I will try is lifting it up with the floor jack and letting it down fast see what happens of course after I loosen the top and bottom A-Arms
07-18-2017, 06:20 PM | #24 |
67-72 parts collector,…
Re: Help me! Please
Do you have a picture of the drop spindle?
I just went through this with another guy and he actually had stock height spindles not the drop spindles the previous owner told him that were under the truck.
07-18-2017, 09:08 PM | #25 |
Re: Help me! Please
That might be a possibility I don't know how to tell if it's a drop spindle all I know is when I was under the truck the spindle said Western chassis on it
