Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 11-23-2017, 06:53 AM   #1
64c10step
Front shocks
Installed some qa1 shocks on my truck but only have approximately one inch of travel on the shock shaft, think the shocks might be to long? Know that the wheel travel is almost double that of the shock shaft just don't think that's enough, any suggestions would be appreciated. Thanks
64c10step is offline   Reply With Quote
Old 11-23-2017, 05:19 PM   #2
Re: Front shocks
Is you truck lowered?
Old 11-23-2017, 10:39 PM   #3
64c10step
Re: Front shocks
Yes, 2" drop in front and 4" drop in back. Thanks for the response.
Old 11-24-2017, 08:56 AM   #4
Re: Front shocks
Are the shock for a lowered or stock height. That could be your issue with the lack of shock travel.
Old 11-24-2017, 09:05 AM   #5
JohnJ@RideTech
JohnJ@RideTech's Avatar
Re: Front shocks
Ideally, you want about a 60/40 mix of compression and rebound travel at ride height. Shoot me over a measurement (at ride height) from the center of the top mount to the center of the bottom mount and I can tell you what stroke you need.
Keep in mind, if you don't have enough compression and rebound travel, you take a chance on bottoming out or topping out the shock. If you do that too much, the shock will literally beat itself to pieces.
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
Old 11-24-2017, 12:44 PM   #6
64c10step
Re: Front shocks
Have just at 11" center bolt to center bolt, thanks for the response.
Old 11-24-2017, 01:59 PM   #7
JohnJ@RideTech
Re: Front shocks
You would need a 3.85" stroke shock for that length. How long have you had the QA1s?
John J.
Sales/Tech
Old 11-24-2017, 05:58 PM   #8
64c10step
Re: Front shocks
Just put them on, there're brand new!
