11-18-2017, 02:34 PM | #1 |
Frame-off Restoration approach question
Looking for some feedback from folks who have restored a basket case.
This isn't for a truck, it's actually for a car (you can read about it on http://1969Pontiac.blogspot.com ) but I'm looking for input on the restoration process, not anything specific to trucks. Basically, I've got a 1-of-1 rare car that's a basket case. Motor, trans, cowl and vin tags, and a rusty body. The car was completely disassembled years ago without rhyme or reason and they just threw bolts in coffee cans and left the pieces inside the trunk or car. I'm thinking I'll need a second car, a rust-free plain two car car to harvest all the little wiring harnesses and fasteners and pieces that I'm no doubt missing. But here's my question: in a case like this, where you're dealing with an unknown number of missing parts, I wonder if it's not worth the additional step of building the complete unrestored car out of the two donors first. Then you blow the assembled car apart and restore it as a whole. The other option is to restore the body of the "important" car and then build it back up with parts, as needed, from the "donor" car. But on a fabrication build you always build the car once pre-paint to see if things fit. I know things will "fit", but I don't know I have all the needed parts. Any input? I've done a full frame off before, but never a "basket case", so it's new territory for me. Thanks, Dave
11-18-2017, 03:10 PM | #2 |
Re: Frame-off Restoration approach question
Rebuilding the car first then redoing it again is a long process. Starting with say the frame, then the motor etc is the way most do it. Those Pontiacs are still accessible in Canada (kijiji etc) but a lot were crushed due to their worth. Not many 2+2 convertibles around, especially with those powertrain options. Good luck
11-18-2017, 05:51 PM | #3 |
Dave, i'm read many of your comments and you are more than capable to do this. Probably the complete scope of the project is a little overwhelming but i would start with what you have in front of you and take it as far as you can. Between forums, ebay, etc, nothing is a mystery anymore. Bolts, clips, harness, etc is avaliable, and if it's a special rare item you probably wouldn't get it with a spare car. A lot of time and expense would be used looking and dragging home a spare. Vendors now sell complete bolt packages for cars, trucks, as an example. I say dive in and don't look back! Good luck.
11-18-2017, 07:45 PM | #4 |
Start with what you have frame suspension drive train body etc then tackle unknown as you go a parts car is never a bad as long as you can get a descent deal but only part it out as you go
70 SWB STEPSIDE 70 BLAZER 09 challenger |
11-19-2017, 06:03 PM | #5 |
I am a Referee of life.
The end result you are looking for would be a good place to start. If it's to be a 100% correct restoration, a donor may have some merit. If you are modding some, such as better brakes, factory options etc. a lot will be aftermarket or off brand rebuilt so a donor would be less help.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
11-19-2017, 08:51 PM | #6 |
IMO a complete parts car would sure be a bonus, finding the right donor? But stranger things have happened, keep looking, asking, searching.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
11-22-2017, 01:12 PM | #7 |
I think when the car arrives I'll go through the parts and see how bad it is... somehow I've got to make an "inventory" of what I'm missing, and I do have an assembled coupe to check against, which is good, but NOWHERE to get any parts.
So it depends on how much is missing and what I need, I guess. If there are tons of little things missing (glove box locks, radio knobs, ashtray lids, rear defroster, I dunno) then maybe a parts car makes sense, since there are no wreckers to visit. If it's just a few parts, then I'd scrounge for those separately. Part of the problem is to know what I'm missing in the first place. I definitely need rear sheet metal, I think, so if I can find a non-rusty 2-door it's a nobrainer. But that might not be easy, and a non-rusty 2-door is going to run 5K I think.
11-22-2017, 01:22 PM | #8 |
So Dave....are you looking for another '69 Canadian Pontiac for parts, miscellaneous, etc?
If so, I can keep an eye out on this side of the pond for anything in my vicinity or on the island... I have good connections on the island from here up to the Comox Valley. In terms of Alberta....I have good connections in Calgary too.....nothing in Edmonton tho'. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
11-22-2017, 01:29 PM | #9 |
I am indeed... unfortunately these cars were quite prone to rust, and while Regina (Saskatchewan) didn't use salt, many cities did. There's not much left... but I bet there could be a few beaters kicking around small towns still!
11-22-2017, 01:40 PM | #10 | |
My in-laws live in Saskatchewan (just outside of Regina) and we are back there every couple of years. There are some amazingly solid older cars and trucks still sitting around in yards, farms, etc. I found a boatload in a wrecking yard near the Alberta border (sask side) 3 years ago....just of the no.1 hwy. I had no time, no tools and no resources to take advantage of the dozens of older trucks and older cars there when I was in the yard. 2 years later I went to visit it again...and the entire yard was gone....emptied, crushed.....gone, nothing but a dirt patch.....damn near cried, lol. Regardless....I always keep my brother in law in mind if I find something nice and interesting in that area. He has a 20 acre farm and a very nice, empty storage building....lol....plus he is a car guy. Coley
11-22-2017, 03:10 PM | #11 |
I would use the parts car as a working guide and not blow it apart as well. Only as needed to figure something out or use a part.
Your biggest hurdle will be the top. I have my dad's 67 firebird which is basically a bare shell. No interior, not much under the hood... I'm going to have A LOT of time and money in researching and buying what's missing... it's not like I can buy a cheap 4 door version, or even a beat up one for any kind of affordable price, so I'll be catalog and pictures building it. You're truck is amazing. You know what to do
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
11-22-2017, 10:58 PM | #12 |
I think a donor is a great idea, even if it takes awhile to find. If the disassembly of the donor is well documented, (photos,video,notes) the "important" car will go together much easier. Your truck is nice and this 2+2 will be too
11-25-2017, 12:35 AM | #13 |
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
Thread Tools | |
Display Modes | |
