Old 03-05-2015, 10:31 PM   #101
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Re: My suburban's Twisted Little Sister
So, am I understanding that you are building more of a Blazer than a Sub?
I like!
Modges'66 is offline   Reply With Quote
Old 03-07-2015, 02:51 AM   #102
JRE
Sweet I love Builds with lot's of body Mods.
JRE is offline   Reply With Quote
Old 03-07-2015, 02:55 PM   #103
65sub
65sub's Avatar
Originally Posted by pimpston65 View Post
HOLD THE PHONE!!!! i know your not making a coupe' burban??? if your are im coming up there to drool, and pick ur left over parts...
Coupe'burban That might be a good description.
Originally Posted by Advanced Design View Post
V12? Cool!...somehow I missed the V12 part of the build.
5.3L jaguar V12 fuel injected
I like!
Kind of like a blazer but a little more "twisted"
Stay tuned. Lots of cutting and welding coming soon.
Dale
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 03-09-2015, 08:27 PM   #104
65sub
65sub's Avatar
Drilled spot welds and separated panels. The factory worker who spot welded the front drip rail was nuts. He had two or three spot welds on top of each other every inch all the way around. Taking them apart really chewed them up
Dale
Old 03-09-2015, 09:30 PM   #105
Modges'66
Modges'66's Avatar
Holy-S!
Really?
Some real work ahead!
Go for it!
Old 03-09-2015, 10:22 PM   #106
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
interesting,,, I see a third piece sandwiched in there that I haven't seen on trucks, maybe a suburban only piece?
that might explain the extra spot welds: the inner piece was welded first, then the outer on top of that...
I am curious to see what is in there.
Old 03-10-2015, 12:01 AM   #107
pimpston65
pimpston65's Avatar
i think its part of the roof support, cuz thats a big piece of metal(roof). i pulled the headliner out of one on a pick. took the supports out to get to it and it was floppy!!!
pimpston65 is offline   Reply With Quote
Old 03-11-2015, 09:09 PM   #108
65sub
65sub's Avatar
Holy-S!
Really?
Go for it!
Thanks Modges. Ya fun starts now
You're right just an extra support about 3" wide all around the front.
It sure is a big floppy roof once it's off
Here's the truck with no roof. For any one removing a suburban roof after you do all the bolts that go down into the side there is a bolt that goes up into the edge of the roof from inside the channel behind the door. There is also a weld that holds the inner roof to the roof support. Above the rear doors there are two rows of spot welds as well as a hidden one in each corner.
Dale
Old 03-11-2015, 09:20 PM   #109
65sub
65sub's Avatar
There is some rust around the front. Some above the A- pillars and along the sides
Dale
Old 03-11-2015, 09:36 PM   #110
65sub
65sub's Avatar
Before the cutting starts we removed the wood floor and then the metal floor up to the back of the doors. We also added some extra supports from the cross brace to the frame
Dale
Old 03-11-2015, 10:07 PM   #111
65sub
65sub's Avatar
Started the cutting on the back just to see whats inside. Found more rust of course. Cut the center post out and then separated the inner and outer panels inside the window channel
Dale
Old 03-11-2015, 11:09 PM   #112
Jeff La
Keep the pics coming, cause that means the works progressing. Can't wait to see more.
Jeff La is offline   Reply With Quote
Old 03-12-2015, 09:07 AM   #113
reaper71
reaper71's Avatar
Looking cool already
reaper71 is offline   Reply With Quote
Old 03-12-2015, 07:42 PM   #114
65sub
65sub's Avatar
More progress and pictures today.
Thanks reaper.
First thing to go was the outer panel. The second picture shows the support between the inner and outer panels. Then we removed the inner panel. Next we did the same on the drivers side. The next step is to move the back forward to meet the front. Since the frame was in the way and is badly rusted we cut the back of the frame off.
Dale
Old 03-12-2015, 09:58 PM   #115
Modges'66
Modges'66's Avatar
Hmmmm, not much left.
This should be a good learning experience!
I am gonna watch religiously!
Old 03-12-2015, 11:09 PM   #116
Jeff La
Can't wait for more. Some great work going on here, really like learning. Thanks
Old 03-13-2015, 02:38 PM   #117
rusty76
rusty76's Avatar
This will be fun.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 03-13-2015, 04:09 PM   #118
joedoh
joedoh's Avatar
neat! so REALLY short wheelbase, like an isuzu amigo? Love the thinking
Old 03-13-2015, 04:19 PM   #119
ptc
ptc's Avatar
Wow.... you guys putting an 8,000 hp Top Fuel Engine in that frame!!!!!
you could!!!!
ptc is offline   Reply With Quote
Old 03-13-2015, 08:29 PM   #120
VictoriaHardware
VictoriaHardware's Avatar
When it's all done how much of the original truck will be left- in terms of pounds? Considering that the truck weighed about 3,700 pounds new, what percentage of the original truck be left- about 25% ?
Also how % much will be weld?
VictoriaHardware is offline   Reply With Quote
Old 03-14-2015, 06:59 PM   #121
65sub
65sub's Avatar
Keep watching. We're not done cutting yet.
Thanks Jeff
Originally Posted by rusty76 View Post
This will be fun.
We're having fun now Rusty
Well short from the door to the back but the door will be lengthened 16"
you could!!!!
I think that much power would scare me
25% is probably a good guess maybe less. 1/2 the quarter panel, 2/3 of the roof most of the doors the dash and the top half of the rear gate and maybe the hood.All the rest will be replaced.
Friday we got the front and back pushed back together. It looks very short in the picture but the door will get extended by 16" soon. We also got the shop cleaned up a little bit
Dale
Old 03-14-2015, 07:36 PM   #122
jonzcustomshop
1961 crewcab
interesting so far... visually after you chop and section it ,it will appear a lot longer and lower.....
Old 03-14-2015, 11:30 PM   #123
jonzcustomshop
1961 crewcab
btw... I was playing with your photo in "photochop"..... as the roof comes down, the upper section of the rear window, and the door frame get longer, so don't throw any of your scrap pieces away yet!**** some of that length could be remedied by leaning the rear post a little bit
when you do the doors if you have an extra set you could cut them both long , and then longer on the top to cut down on the welding and body work..
Old 03-15-2015, 02:05 AM   #124
pimpston65
pimpston65's Avatar
INSANE!!! add another awesome unique build to the list that folks will be talking about for a very very long time. oh you converted a long bed into a shortbox, thats nice. bet you never converted a suburban into a coupe'!!! will that side window be a slider? i may have an extra lock...
Old 03-15-2015, 02:23 AM   #125
Grizz1963
Grizz1963's Avatar
Funny how things move on at different pace for everyone.
Yours is suddenly a light year ahead.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
