Old 11-24-2018, 06:08 PM   #1
Rustybug61
No heat in cab
Fan switch works all speeds. Heater core is clean. Water flows. Sitting in driveway, I can feel heat blowing but as soon as I drive, air is ice cold. What gives??
Rustybug61 is offline   Reply With Quote
Old 11-25-2018, 08:49 AM   #2
Re: No heat in cab
It sounds like one of the doors is not in the proper position. The cold air is not passing over/thru the heater core and just coming directly in. Not sure where to test/start looking. Hopefully one of the more knowledgeable folks will chime in for ya.
Palf70Step is online now   Reply With Quote
Old 11-27-2018, 09:00 PM   #3
diveplane
Re: No heat in cab
sounds like a sticky actuator under dashboard they are 2 if i remember in 1500
mine has anyway. one controls the vent blend door other switches modes from
defog top off dashboard to vents to floor or a mixture .
wd40 many cases unsticks the small pistons.
diveplane is offline   Reply With Quote
