12-25-2023, 11:40 PM | #1 |
Fuel Pump Question
My fuel pump took a crap and I was going to install one from O’Reilly’s and mentioned it to a buddy and he offered up this NIB Carter. It’s supposedly a high flow pump and seems much more substantial than they new one from O O O O’Reilly. I’ll have to buy a few new fittings for it to make it work with my plumbing, but is there any reason NOT to use the Carter?
1969 GMC K25 2007 Chevy 2500HD Classic Duramax 1999 Tahoe 2DR 4WD Base Model 5.7l |
12-26-2023, 12:49 AM | #2 |
Re: Fuel Pump Question
I would figure out what’s cheaper, the fittings you need to make the Carter work, or the fuel pump from oreillys. Whichever saves $$$ would be the route I’d take. Either way works.
12-26-2023, 10:37 AM | #3 |
Not sure as to what "New Fittings" you require but that Carter is clockable.
12-26-2023, 12:48 PM | #4 |
70+ ( Old Skool Club )
I put this one on my truck in 2021 when still had the original 350 and went to the rear mounted tank. I replaced the engine with a redone small block 400 last summer (2022) and it working fine. I guess not cheap as I just looked and its 75.00 US now but I'd rather have something that will do the job long term that worry about 20/30 bucks more for something.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
12-26-2023, 12:58 PM | #5 |
I recently replaced the pump on my 307 with one I got at Napa. Threads were stripped inside the outlet port. Hard line would not screw into it. Replacement was from CarQuest was cheaper and worked perfect. I used a stud instead of a blot on the inside mounting to make installation easier. Helps align the pump while tightening it up.
71 C-20 07 Magnum RT AWD |
12-26-2023, 01:29 PM | #6 |
It depends on how old it is. Some old pumps had materials that were not compatible with fuels with ethanol in them. Some old pumps can have the diaphragm dried out.
George |
12-26-2023, 03:20 PM | #7 |
I am running NOS AC fuel pumps on all of my vintage GM vehicles. I have non-ethanol fuel in this area for them. No failures from any of them.
I have more trust in a 40-50 year old US made pump than a brand new Chyna pump.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
12-27-2023, 09:40 AM | #8 |
I've used those Carters several times over the years with no issues. Carter used to sell replacement diaphragm kits for them. As long as the pivot wasn't worn out you could rebuild them. We have one on my buddies GTO that runs 11.20's.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
12-28-2023, 04:50 PM | #9 |
Fuel presure. The pump's pressure vs the carb's recommended operating pressure. You need to find out those values. If its too much pressure for the carb, it'll flood and run like crap.
72 C10 lwb fleetside -stock 350/350 combo |
12-28-2023, 05:03 PM | #10 | |
That Carter pump will be higher quality than an off-the-shelf [asian] fuel pump from ORAP.
12-28-2023, 07:42 PM | #11 | |
No reason not to run it, especially if it is low priced. Plus it's rebuildable! Pretty sure this is the kit. https://www.summitracing.com/parts/crt-888562
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 12-28-2023 at 07:48 PM. |
12-30-2023, 05:52 PM | #12 |
Got a $19 Carter from Summit. Works perfect with my Eddy carb. FP gauge says 5.5 PSI. All good
12-30-2023, 10:25 PM | #13 | |
12-30-2023, 10:27 PM | #14 | |
12-30-2023, 10:31 PM | #15 |
It’s a stock 350. I’ll check the model # on the Edelbrock.
12-31-2023, 12:50 AM | #16 |
Then you should be fine, as the Edelbrock Performer is essentially the same as a Carter AFB. I run a Carter AFB 9635, 600CFM. [It's about the same as an EDL 1405.]
An L6 would have a fuel pump that's ''inverted'' from the V8 orientation. I don't know if flipping a fuel pump has any effect on its operation. But I've always used the pump specified for each engine type.
12-31-2023, 10:12 AM | #17 |
So, once again, check those pressures. Edelbrock recommends a fuel pressure regulator set to 5.5 psi, or their fuel pump which runs at 6 psi.
