06-18-2018, 11:53 PM | #1 |
1980 c10 250ci gear ratio
1980 C10 LWB, 250ci rear gear ratio in 12 bolt?
Not my truck, looking to get a better gear ratio for towing. No spid either |
06-19-2018, 06:13 AM | #2 |
Re: 1980 c10 250ci gear ratio
2.73 most likely, based on my 78 and 82.
2.56-3.73 possible. 3.43 works decent for towing. Remeber with a 250 you're not going to run 70mph down the highway with a car hauler.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
06-19-2018, 08:40 AM | #3 |
I have a 1978 Big 10, It has a 350/th350 combo and has 3.08 gears. Was hoping it would have 3.42 or 3.73 gears behind that 250 parts truck.
06-20-2018, 11:45 AM | #4 |
My 250 got a 3.08.
Bonus to a 3.08 already in your truck is you already have the 3 series carrier. Just buy a set of gears to where you want it to be, cheaper than a whole rear end just to rob the gears from. |
06-21-2018, 07:16 PM | #5 |
The local mechanic wants 1200 to set up rear end with gears. The other axle is $100
06-22-2018, 03:38 AM | #6 |
3.42 was an option for a 80 250, if the rear GVWR is 5600 or 6000
06-24-2018, 03:26 AM | #7 |
MY '78 250 3ott truck has 3.73's
06-24-2018, 10:02 AM | #8 |
06-24-2018, 10:44 AM | #9 |
About the only option my truck had from factory in '78 was the 3.42 rear gear. It was a 250 inline 6 with the 3 on the column.
1978 Hawaiian Blue GMC 454/Tremec TKO 500 BUILD THREAD |
