Old 05-20-2018, 09:25 PM   #1
hevymetl
New door rubber installed now doors are SUPER tight
Just installed new weather stripping on door openings of my 66 c10. Po had taken them off prior to my purchase. Now my doors are insanely tight. Hard to open and have to slam them way too hard to close them. Is the latch plate adjustable? Should I wait and let them compress a little?
hevymetl is offline   Reply With Quote
Old 05-20-2018, 10:32 PM   #2
Ken Cook
Ken Cook's Avatar
Re: New door rubber installed now doors are SUPER tight
The latch plate is adjustable. I would loosen it but I think you’re right that they will compress some. I would also leave it in the sun and see what happens.
You might also check the thread in FAQ. It talks about using whether stripping from a Honda, I think.
Ken Cook is offline   Reply With Quote
Old 05-21-2018, 06:52 AM   #3
PGSigns
PGSigns's Avatar
I used the Honda seals and they have been good. Fit is nice and they seal well.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-21-2018, 07:59 AM   #4
bigboar
Jimmy
same here...work great. best of all, no adhesive.
bigboar is offline   Reply With Quote
Old 05-21-2018, 12:20 PM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Ditto
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-21-2018, 07:02 PM   #6
Railroader
Railroader's Avatar
Did you change sill Plates? I did when I replaced door weather striping and that was causing my door problems. If you did change sills, remove them and see if doors shut any better.
Railroader is offline   Reply With Quote
Old 05-22-2018, 12:37 PM   #7
hevymetl
I did not change sill plates. The new rubber came with the truck I just got around to installing it. I'm gonna leave it sit with doors closed for awhile, I don't drive but once a week or so. Hopefully they flatten out a bit. If not I'll have to adjust. Thanks for the replies.
