Old 01-20-2011, 01:35 AM   #1
darkone
Rattle can over Metal Patch Body Filler? is it safe?
Hey all,
Ive done a lot of body work with metal patch body filler. it says it should be painted over with a urethane paint. my question is: can i use regular rattle can paint over the body filler to seal it & protect from water? also, will rattle can paint affect the type of paint i ultimately use when painting with primer/base coat/clear?
thanks in advance for any help
darkone is offline   Reply With Quote
Old 01-20-2011, 01:37 AM   #2
mwilliams5891
Re: Rattle can over Metal Patch Body Filler? is it safe?
I know it doesn't help....but subscribed
-1969 C/10 Short Step soon to be Brand NEW Ls6/T56
-03 Mazda Protege 5
-WTB 1970 Chevelle project
mwilliams5891 is offline   Reply With Quote
Old 01-20-2011, 07:34 AM   #3
CURSED GEARS
I dont recall using spray paint on my truck, but did use spray paint primer while doing my truck. when it was all done i then used regular primer and paint. Its been 10 years and nothing ever peeled, or faded or came through the new paint.
CURSED GEARS is offline   Reply With Quote
Old 01-20-2011, 08:30 AM   #4
I don't see why not,as far as been rattle can. I don't know about the filler you used but never heard of urethane being required.
Old 01-20-2011, 08:36 AM   #5
bigsnookmaster
bigsnookmaster's Avatar
Home Depot sells Rustoleum Industrial Enamel for about $5 a can. I've used it on several things and it works and covers very well. .02
bigsnookmaster is offline   Reply With Quote
Old 01-20-2011, 09:18 AM   #6
My friend is a sign painter...letters,pinstripes,air brush,murals,and in this economy does small body jobs and overall paint jobs. He has been a long time believer in using the best and swears by Imron and other top quality paints (been in business 35 years). But,he also will use primer from TSC when keeping price low is important. It's the same primer they put in rattle cans.
Old 01-20-2011, 09:24 AM   #7
67swb72klb
67swb72klb's Avatar
realy should use a self etch primer but i have seen others work as well i would not expose it to too much weather it will rust under it
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 01-20-2011, 09:25 AM   #8
lakeroadster
Rustoleum has rattle can filler primer. I have used it and it is thick and covers well. Also has an "Any Angle" spray tip and a big comfort finger tip. For rattle can it is the closest thing I have found to real "spray gun" applied primer.
http://www.rustoleum.com/CBGProduct.asp?pid=11
lakeroadster is offline   Reply With Quote
Old 01-20-2011, 01:30 PM   #9
darkone
can anyone else verify this? i have lots of self etch primer. i actually used self etch on the bare metal underneath the body filler. should i also seal my metal patch & metal glaze with self etch? thanks!
Old 01-20-2011, 01:42 PM   #10
mahanian
C10 addict
mahanian's Avatar
If you self etched the bare metal I don't see the need to do it again. If you are wanting to protect it from water because you plan to leave it primered for awhile your best bet would be an epoxy primer. In my opinion the primer will make or break a paint job, so this is not the point to cut corners. I would buy a quality epoxy primer and seal up all the metal work. You can use a builder/filler primer later down the road before you block sanding and paint. Filler primer holds moisture and will not seal up your metal work.
mahanian is offline   Reply With Quote
Old 01-20-2011, 10:01 PM   #11
darkone
but self etch primer is a good choice? i have a lot of this. can i put a high build primer on after the self etch primer? sanding of course would be done in-between
thanks guys, i just want to avoid any problems
Old 01-21-2011, 08:57 PM   #12
darkone
^bump for answer to directly above
Old 01-23-2011, 12:41 AM   #13
darkone
bump again for comment 2 ^^?
Old 01-23-2011, 06:23 PM   #14
mahanian
C10 addict
mahanian's Avatar
I don't know enough about self etch primer to know if it can be relied on as a sealer as well. That would be a question for the primer manufacturer to get a reliable answer. But in my opinion epoxy primer is your best bet if you are going to leave it primed for awhile before paint.
