09-22-2020, 01:07 PM | #1 |
Screw seized on door panel
I have 2 screws left on the driver’s side door panel that are seized. I have been regularly hitting it with PB blaster which has worked wonders on everything else so far, but still those 2 won’t budge. I’m guessing since it’s a vertical surface the oil isn’t soaking down into the threads as good as it could be. The heads are starting to strip so that’s a second problem. I did get one out yesterday with a screw extractor and an impact gun at low speed, but that was touch and go. So now I’m left with these 2 and I have so much work to do on the doors.
Am I completely missing a trick of the trade here? What can I do to get these stupid bolts out?! PS: Go easy on me, I’m a girl. Last edited by 4thgencreamsicle; 09-22-2020 at 01:14 PM. |
09-22-2020, 01:26 PM | #2 | |
Re: Screw seized on door panel
1968 GMC C2500 Long Bed Fleetside |
09-22-2020, 02:26 PM | #3 |
If worse comes to worse. Drill off the heads, leaving the shafts. Add a little heat, tap with a small hammer. Attach a vise grip to the shaft and try to back it out. After the heads are drilled off you should be able to remove the panel and have better access to the shanks. Good luck. Make sure to run a tap through all the receptacles prior to assembly to remove existing rust.
Smitty '71 Short Fleetside Spring Valley, Ca. |
09-22-2020, 03:44 PM | #4 |
like mentioned above, I find it easiest to drill the heads off, remove the panel, and deal with the screw shanks that are left..
grooming the heads of the screws with the panel on is asking for trouble, very difficult to work there without damaging panel.. sharp drill bits, strong low speed drill, patience.. use controlled pressure to get big chips but don't want to run off into the vinyl.. once the panel is removed, soak screws with copious amounts of pb blaster, kroil, wd, whatever penetrant you prefer.. use vice grips with a good sharp jaws and square edges that will allow it to bite every bit of what's protruding.. don't want to mangle what's left into a nub, get a solid bite and work it loose.. sometimes the corrosion is heavier on the tail of the threads (part inside the door) so it may thread in or tighten easier than out.. not far, just enough to break it loose and then work it back and forth, a little more loosen each time until it runs all the way out.. chase the threads with a tap and lube.. I believe mine were all 1/4"-20 but you'll need to verify that on your doors.. by the way, I've had to do this for several screws out of each of the four sets of panels I have removed so don't feel bad.. good luck!
I started out with nothing - and I still have most of it |
09-22-2020, 04:40 PM | #5 |
Agree with above. As drilling goes, in case you're not used to it, apply oil to the bit and/or screw. Use the smallest bit you can get away with without busting one, you shouldn't need more than an 1/8" for a 1/4" screw. Smaller if the problem is the stainless steel above the panel, those screws are #10.
Bits generally bust because of not shooting straight right. Personally I'd use a good bit, IRWIN has never let me down, drilled 3/8" grade 8 bolt for me too, through the thread top to bottom (yikes). Spraying with water as you drill helps too, bits like to be cool. Defeats the purpose to have a bit spin going nowhere.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
09-22-2020, 05:26 PM | #6 |
Who Changed This?
If you can find them, use left hand drill bits. If the bit catches, it just might back the screw out.
https://www.harborfreight.com/screw-...SABEgIJGvD_BwE
09-22-2020, 06:55 PM | #7 |
I had 1 or 2 of the nuts on the door come off when I was used some force getting the bolt out. I replaced the nuts with 1/4-20 cage nuts from the hardware store. So if you get forceful with it and that happens, not to worry.
A nut that survived A cage nut |
09-22-2020, 08:51 PM | #8 |
As you run the drill thru the screw, stop and see if the heat from drilling has loosened the screw up.
09-23-2020, 11:23 AM | #9 |
I had to do this recently. Drilled the head off and used a vice grip to remove the treaded part.
71 C-20 07 Magnum RT AWD |
10-02-2020, 09:46 PM | #10 |
Put valve grinding compound on the screwdriver tip and on end of screw it will either break loose or will break the head off the screw or the screwdriver
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=265847 |
10-02-2020, 10:45 PM | #11 |
10-02-2020, 10:53 PM | #12 | |
The OEM door panel screws have a smaller head than the 1/4-20 threaded shaft. I have had to drill off the rusted screw head and then replaced the clip nut [or Cage Nut].
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 10-02-2020 at 11:03 PM. |
10-03-2020, 10:56 AM | #13 |
I ended up mangling the nuts and messed the hole up as well, a 1/4” rivnut went in the hole perfectly with the added benefit of being stainless so it won’t seize up again.
10-03-2020, 02:12 PM | #14 |
When I replaced mine I used SS screws with a dap of anti seeze.
10-03-2020, 09:29 PM | #15 |
So here's my .02 on drilling out any bad bolt. If the head twists off and it's a bit above the surface take a grinder and grind the bolt so it's completely flat. If its a small bolt like a 10-24 or 1/4-20 get small diameter center punch and sharpen it to a needle point. Then the best you can center punch the bolt right in the center of the bolt. If your first try is a bit off center just do it again make the punch mark heavier so the drill bit doesn't walk. Start with a really sharp 9/32" bit and drill all the way thru the bolt. Then drill the bolt with a 5/32" bit and the final size drill bit is 13/64". If you center punched correctly the 13/64 drill bit (or #7 drill bit) is the tap size for a 1/4-20 bolt. Re-tap the hole. Even if its a bit off you should be OK.
Good luck. |
10-04-2020, 09:16 PM | #16 |
My suggestion here is if you need to drill in steel, locate a split tip cobalt bit of the correct size. Generally speaking, they cut better than anything else you’re going to find. They’re a little more money, but they ~cut~. In steel, use heavy pressure, low speed.
Posted via Mobile Device |
