Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 08-08-2020, 06:31 PM   #1
Patch
Patch's Avatar
Argon bottle size
Hi all. Getting everything together to start the panel replacement on my 72 cab
For this type of Mig welding, what is a sufficient bottle size for my 75/25 gas? Do I really need a 200-250 CFT bottle? Rockers...1 side floor pan...cab corners....the normal. Thanks in advance.
Patch
Patch is offline   Reply With Quote
Old 08-09-2020, 12:53 PM   #2
AZ 67 C10
AZ 67 C10's Avatar
Re: Argon bottle size
Unless you are welding for a living i'd get a bottle that you can move easily especially if it isn't attached to your welding cart. I would rather make an extra trip to have it filled vs having to haul a 6' 100LB+ cylinder every few years to get it filled. I use a 80 and do a decent amount of welding, it gets filled about every other month. It might be enough to do your repairs at that size.
1967 C10 SWB 6.0 LS swap in progress
2011 CCSB Duramax 4x4
AZ 67 C10 is offline   Reply With Quote
Old 08-09-2020, 01:46 PM   #3
Dead Parrot
You can do a lot of welding out of a 150. Anything larger starts getting into the risk of back or other joint injury trying to move it around unless you do that type thing on a daily basis.
Plus, the gauges will give you lots of warning before you run out of gas. Easy to pick a stop point and go for a refill.
Dead Parrot is offline   Reply With Quote
Old 08-09-2020, 01:58 PM   #4
Getter-Done
Getter-Done's Avatar
I have an 80 and does me just fine.
Its small enough to fit on the cart.
And if I leave it open or have a leak ,I am not out much.
84 Chevy K-20
Old 08-09-2020, 08:18 PM   #5
sweetk30
sweetk30's Avatar
now i run a 330 cf bottle but i weld a LOT . i make sure the screw on cap is good and pick it on / off with the engine hoist .
80 is o.k. but i would shoot for 150 if possible . good all around size i think .
also how far a trip to get refill ? and weekend hr's ? this will help you pick a size of bottle .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 08-09-2020, 08:22 PM   #6
mongocanfly
mongocanfly's Avatar
I've got 75/25 in the 150
And 100% argon in a 300...
The 300 is a heavy mother...
The 150 is a good all around common size...talk to your supplier..
I bought my bottle , so no rental..
Like said , a 150 will do lots of welding..
only problem I have with the 150 is it always runs out on fri afternoon
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-09-2020, 09:28 PM   #7
Patch
Patch's Avatar
Thank you all for the advice! Central Welding is only about 20 minutes away, and I think they are closed on the weekends. If I can swing it I will aim for the 150
I'll be doing a lot of spot/stitch welding, so I know it wont be getting used as efficiently. Thanks again!
Patch
Old 08-10-2020, 11:19 AM   #8
wixthedog
wixthedog's Avatar
I've ran the 125 in 75/25 for years now (owner bottle) and even when I am welding a lot (hours a day) I have never been upset by its size and its easier to move around with one man in and out of the truck bed. Even an 80 would be fine to be honest.
Mike
1976 C10 RCLB - 350 - SM465 4 Spd - 4.5"/6" Drop
Obligatory Build Thread HERE!
1979 C20 RCLB - 350 - TH350 Auto
wixthedog is offline   Reply With Quote
