Old 04-26-2017, 11:57 PM   #26
UKNOWME
UKNOWME's Avatar
Re: front brakes: 1" vs 1.25"
Originally Posted by Sinisterv10 View Post
Well i picked up some bearings from the parts store and apparently i have the spindles that go with the 1.25" rotors so the camaro rotor swap is out unless i get aftermarket lowering spindles or stock 1" spindles. Since the truck is not a DD im having the rotors drilled for now while decide. Thanks for the info.
Sounds like you're already going the easiest and most cost efficient route.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 04-27-2017, 02:06 AM   #27
Sinisterv10
Found me some rotors with literally no wear but had them turned just to make sure i start fresh. Got new bearings then had them re drilled. The drilling was done with a CNC machine and the quality is very good. I thought the holes were kinda close to each other for my liking but i liked the fact that the support lugs on the back remained intact.Name:  20170426_175437.jpg
Size:  27.2 KB here is a picture of the front and back.
Sinisterv10 is offline   Reply With Quote
