02-10-2018, 11:23 PM | #1 |
8.1L 4L85E 5.13 gears 37” tires
Have a 91’ K5 with 8.1, 4L85, 5.13s and 37” tires. This truck will eventually see some decent highway time and possibly some towing 5-8k. Currently cruises at 70mph in the 2200-2300 range. Is this a healthy number for towing/ extended highway time or should I be looking to make some changes ?
Thanks it advance |
02-11-2018, 12:09 AM | #2 |
Re: 8.1L 4L85E 5.13 gears 37” tires
you should be fine as-is the 8.1 will pull whatever you want and 2000-2300 rpm at 70mph is not bad
4x4k30 if trouble was money i would have plenty |
02-11-2018, 12:13 AM | #3 |
Post Whore
according to my calculator if your trans has a .75 od you should be turning 2446rpm at 70...good enough I wouldn't change anything. ...and not worth the cost to change it....
http://www.csgnetwork.com/multirpmcalc.html
02-11-2018, 12:26 AM | #4 |
For some reason I thought OD was .70, but I stand corrected (thank you for the calculator). I guess I’ll leave it be
02-11-2018, 12:31 AM | #5 |
Post Whore
my quick search on the od ratio said the 4l80 and 4l85 are the same at .75....
