Old 01-30-2019, 06:49 PM   #1
Praxiss454
Praxiss454's Avatar
Is my balancer fully on?
Hi guys,
It sounds kind of like I'm bottomed out, but I'm not 100% certain. Does this balancer look like it's on there all the way? Chevy 230.
I was thinking maybe it is still off by 1/16" - 1/8". I've been using a sheet of 3/4" plywood on the face, and smacking the hell out of it with a hammer. I've also been whacking on it with a heavy rubber mallet. I tried putting ice on the crank nub to cool it down, and poured boiling water on the balancer to heat it up, that helped me get it to where it is now.
My Truck Thread
1965 GMC 1000 SWB Fleetside L6 230
Praxiss454 is offline   Reply With Quote
Old 01-30-2019, 07:16 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Is my balancer fully on?
Looking back at my pic when I rebuilt my 250, it appears to be at the same location as yours. Sorry it's not closer but if you look at the taper on the end of the balancer, it looks to be like yours.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-30-2019, 09:00 PM   #3
sweetk30
sweetk30's Avatar
i know guys get away with it but you do know wacking them on can DESTROY the thrust flange on a crank shaft
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
sweetk30 is offline   Reply With Quote
Old 01-30-2019, 09:19 PM   #4
Praxiss454
Praxiss454's Avatar
Do you have alternate installation instructions? I'm trying to follow my GMC maintenance manual, which says to drive it on until it bottoms out against the gear. There are no threads on this style of crankshaft. Heat+Cold and a hammer is the only way I'm aware of.
My Truck Thread
Old 01-30-2019, 09:50 PM   #5
sweetk30
sweetk30's Avatar
never played with one so i aSSumed it had threads . . .
Old 01-31-2019, 01:20 AM   #6
Praxiss454
Praxiss454's Avatar
Threads would sure make it a hell of a lot easier.. I was a bit worried that railing on it would cause damage but I'm not sure what else to do. I'll probably try a little more heat/cold tomorrow to see if it moves at all or if I can tell for certain that it is bottomed out.
My Truck Thread
Old 01-31-2019, 11:23 AM   #7
AcampoDave
AcampoDave's Avatar
Do the pulleys align?
AcampoDave is offline   Reply With Quote
Old 01-31-2019, 11:42 AM   #8
Dead Parrot
^^^ Check this. Would really suck to find out out it is on too far when you go to put on belts.
If you have a can of that 'canned air' hold the can upside down and spray the divot on the crank to quickly cool it.
Dead Parrot is offline   Reply With Quote
Old 01-31-2019, 11:54 AM   #9
weq92f
Yeah, check if your pulleys line up. If so... you're golden!
If not... Ditch the boiling water. You need a torch to put enough heat into the balancer. Just be sure you don't over heat it!
But, if yor belt lines up properly, no need to mess with it any further.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 01-31-2019, 12:09 PM   #10
Praxiss454
Praxiss454's Avatar
The balancer sticks out about 1/8th inch farther than the fan pulley. BUT it is my understanding that the water pump pulley mount is press fit on to the shaft and, compared to my old pump, is pushed farther back. I think I can use a puller to pull it forward if necessary. I'll mount the alternator today to check for alignment and see how things look.
My Truck Thread
Old 01-31-2019, 12:11 PM   #11
chevy_mike
chevy_mike's Avatar
Yeah, I didn't want to beat on it so I drilled and tapped the crank and used a standard SBC installer to press it on. Didn't take long to do this, as the crank is cast and easy to drill and tap.
Old 01-31-2019, 12:43 PM   #12
PGSigns
PGSigns's Avatar
Hard to tell from the picture you have posted but it looks like the outer ring on the damper is pushed back further than it should be. They are normally closer to being flush with the front.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-31-2019, 05:38 PM   #13
SunSoaked
SunSoaked's Avatar
Wow! That's REALLY old school. Lol
SunSoaked is offline   Reply With Quote
Old 01-31-2019, 10:09 PM   #14
YoungPup1977
YoungPup1977's Avatar
This forum is called 1947 to present.......so some of this is OLD school....LOL!!!!!
YoungPup1977 is offline   Reply With Quote
Old 02-01-2019, 03:58 PM   #15
61K10
61K10's Avatar
when i started back in the 60's a BFH was your best friend--still is at almost 70 yrs old lol.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
