Old 02-11-2019, 09:10 PM   #1
GTS61
Exciter wire
I installed a new alternator and I see the brown wire under my dash but donít know where it goes. I was wondering if I can cut the wire and put a Y so the wire will go to my ignition switch and to where ever else it goes?
GTS61 is offline   Reply With Quote
Old 02-12-2019, 01:17 AM   #2
69 C10 LWB
Re: Exciter wire
Are you replacing an older externally regulated alternator with a new internally regulated? Or are you just repalcing with a factory replacement? I installed a newer alternator on my truck and there is a wire that runs from the light to the voltage regulator. I removed it from the regulator and ran it to the terminal on the back of my alternator. The light on the dash works and it charges like it should.
69 C10 LWB is offline   Reply With Quote
Old 02-12-2019, 01:39 AM   #3
GTS61
Re: Exciter wire
Yes I installed new alternator with internal regulator. I tried using the wire off of the external regulator and my truck dies after a while. I traced it to under my dash and then I lost it above the steering column. Thatís why I was asking that question. I guess Iíll have to find where the other end goes or Iíll screw something up. Thanks for the info! I donít have a light but I have a volt gauge.
Old 02-12-2019, 12:14 PM   #4
MusicMan70
MusicMan70's Avatar
Re: Exciter wire
GT,
Read through this article on upgrading your system
http://www.madelectrical.com/electri...hreewire.shtml
It will help you to upgrade your charging system.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 02-12-2019, 08:07 PM   #5
GTS61
Re: Exciter wire
Thanks, Iím looking into it now!!
Copyright ©2000 - 2019, vBulletin Solutions Inc.
