Old 10-11-2018, 06:49 AM   #26
homemade87
Re: Making A New Oil Pressure Line.
Originally Posted by LostMy65 View Post
I had the nylon tubing in my 66, and it became brittle and split and blew oil all over my father-in-laws driveway.
I've read of guys having them spray all over under their dash.
I guess that would have been worse.
I'm replacing mine with copper.
However, I have read of some saying that copper may crack from vibration.
Has anyone heard of or had an issue with the copper tubing?
Copper tubing does become harder over time . If not properly looped for stress relief the vibration will crack it premature . You are correct that copper can fail , this is why the auto industries does not use it . I even had to replace the copper tubing on my air compressor a couple times . Not good in a vibration environment .
homemade87 is online now   Reply With Quote
Old 10-11-2018, 11:42 AM   #27
damnyankee36
My 66 has a steel line which I assume is original. There is no loop in it either.
Is steel w/o a loop correct? I need to look in the AIM to see if there is good illustration on the instalation.
damnyankee36 is offline   Reply With Quote
Old 10-11-2018, 10:11 PM   #28
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Yeah, steel I read was original.
66 Service truck build:
Old 02-08-2019, 10:47 PM   #29
v30crewcab
v30crewcab's Avatar
is there anywhere to get the steel line anymore?
88 military v30 crewcab shortbed
5.9 cummins, nv4500, 205
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 02-09-2019, 04:26 PM   #30
ray_mcavoy
Yes, steel tubing is still available but it's not as easy to find as copper in this size. One source I've found is Lincoln Industrial. Their part number 62175 is a 25 foot roll of 1/8" OD steel tubing.
ray_mcavoy is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
