Old 02-08-2019, 12:41 PM   #1
ChuckLee
what you guys paying to have 12 bolt put together?
Can't believe local shop wants $550 to put together my 12 bolt (i supply rebuild kit, auburn posi, gear/pinion, and 1350 yoke).
That seem high?
I'm in Richmond, VA
I was expecting like $200 but what do I know!
I don't have any experience but wish I could just do this myself
LS Swap build thread http://67-72chevytrucks.com/vboard/s...d.php?t=722579
ChuckLee is offline   Reply With Quote
Old 02-08-2019, 12:58 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: what you guys paying to have 12 bolt put together?
$100/hr labor. Are they refinishing the housing (blast, powder)?
I doubt they would take it apart, clean it, and put it back together in under 2hrs, but then again I don't rebuild rear ends all day. $500 doesn't seem insane, but i think it'll really depend on what the actual scope of work is. I ran into the same issue with price swings on trans rebuilds, based on whats actually being done.
If it can come apart and go together in 2hrs, maybe just do it yourself and take a little longer? Rear ends aren't crazy hard, but the setup can be tedious.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-08-2019, 01:16 PM   #3
ChuckLee
All good points. To be more clear:
I will bring housing to them with axles out. Old carrier needs removed, new seals and bearings installed, new posi installed, gear/pinion, and yoke. Thatís me supplying all parts. For a diff shop you probably right, under 2 hours for them.
Old 02-08-2019, 01:53 PM   #4
kwmech
Everything only takes 10 minutes. If they are doing a quality job....pulling it apart, inspecting everything properly, cleaning, reinstalling, checking pattern, readjust if necessary.(insert sarcasm here) Yup, 10 minutes. Slam bam get it out the door DGAF yeah under 2 hours. Seriously though, with brakes and shafts removed, blow apart, clean and a quality set up--- at least 3-4 hours without it giving them any problems.
Old 02-08-2019, 02:17 PM   #5
tdangle
tdangle's Avatar
Plus you are paying for their experience, and special tools needed to set it up correct. I don't think $500 is that out of line.
Terry
1970 C20 Custom Camper, 350/2004R, Dana 60, factory AC, side tool box
tdangle is offline   Reply With Quote
Old 02-08-2019, 02:26 PM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I paid that and had all parts ready, housing steamed/blasted clean and painted, new brakes assembled off the diff and ready to go.
Total with posi and all, around $1400, 5 years ago.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-08-2019, 09:08 PM   #7
Mike C
Mike C's Avatar
I charge $250 to do a rear and $350 to do a front from my home shop. In general, I charge $50 an hour and it's impossible for me to do front and rear in a 10 hour day unless everything goes absolutely perfectly. And we all know how often that happens...
But if you are just swapping in the carrier and NOT changing the ring and pinion setup that doesn't take as long. But if they are swapping bearings and you expect them to run a pattern using OEM gears you will have a hard time getting it done for less. Are you expecting them to replace pinion bearings? I assume you are having them put new bearings on the diff carrier or they removing your originals and re-using? I would expect them to completely assemble it back together for that money.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-08-2019, 10:18 PM   #8
mongocanfly
Wish you was closer to here Mike...I'd put you to work....its hard finding anyone local to setup r&p...and I hate doing it....
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
mongocanfly is online now   Reply With Quote
Old 02-08-2019, 10:28 PM   #9
sweetk30
sweetk30's Avatar
i have done some and 2-3 check and good . then i did a vett rear center diff and that thing kicked my butt and still wasn't happy with b/l and it all looked good so i shipped it . the richmond gears he supplied wanted 11-12 tho b/l WOW i think that's crazy . most i could get was i think 13 tho b/l .
its experience / tools / and lots of patience .
and fyi : master ring and pinion kits do NOT come with axle bearings out at the ends of the tubes or the seals . there just ring and pinion parts . lots of people think they do .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
sweetk30 is offline   Reply With Quote
Old 02-09-2019, 09:45 AM   #10
Mike C
Mike C's Avatar
I agree with that all around!
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-09-2019, 12:38 PM   #11
B. W.
B. W.'s Avatar
I've read a lot of your posts & it's obvious you very experienced. When you said "10 minutes" I almost spit out my coffee! But don't you love it when the first thing a customer says is "it's real easy, it'll only take ten minutes!"
I agree, 3-4 hours is legit. I've had them go together a lot quicker when everything sets up perfect. Or longer when things go south.
B. W. is offline   Reply With Quote
Old 02-09-2019, 12:41 PM   #12
Coley
Coley's Avatar
Smile Re: what you guys paying to have 12 bolt put together?
$500 is a good deal.
You have to look at it this way...what is your time worth? or what do you do for a living?....are you worth $500 for your skills and several hours and particularly, the responsibility of the result? the answer is probably: yes.
$500 is not a lot of money today for labor on anything....seriously.
Hard skills like those needed to do this properly are worth a few bucks...and this cost is probably only going to go up over time, given the limited amount of people learning this skill.
Or think of it this way....if you go into a new GM dealership to buy something....set of hubcaps? 1 or 2 rims....you will be dropping $500 in a heartbeat.
If you go to a German car dealership...that will probably get you an appointment
If you decide to do it yourself make sure you read up on what it takes skills wise and very importantly...'tool wise', let alone a good space to do it.
After spending a 1-2 days on it the $500 might not sound like such a bad thing, lol.
All good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 02-09-2019, 03:19 PM   #13
mongocanfly
I know a buddy of mine bought a complete unassembled chunk for his 9in ...new carrier ,gears ,r&p....where he bought it they said they would assemble and set up for $250...after a long weekend he wishes he had spent that extra 250
Mongo...aka Greg
Old 02-12-2019, 02:58 PM   #14
AZ 67 C10
AZ 67 C10's Avatar
Do they warranty their labor/workmanship? If so, depending on their warranty $500 isn't a bad deal. I was going to do something similar to you and take an empty housing and a pile of parts and have a shop build my rear end. After talking to them it made more sense to let them buy all the parts and build it and give me a full warranty- parts and workmanship. This way there's no back and forth if something fails, its all on them to make it right.
AZ 67 C10 is offline   Reply With Quote
Old 02-12-2019, 03:16 PM   #15
ChuckLee
I bought a shop press and a decent dial indicator. Every time I pay someone else to work on my stuff Iím not impressed and I know Iím overpaying. This is a great example. What I do know is that any shop that specializes in this work, if they canít do it in 3 hours they arenít specialists. Iím not having them clean anything, just install all bearings and seals, ring pinion, and carrier. Iím not paying ANYONE $200/hr! Nope nu uh
(Watch my next thread title be, ďhelp guys my rear end is making this really weird noiseĒ)
Old 02-12-2019, 09:50 PM   #16
Mike C
Mike C's Avatar
I don't blame you one bit. After I broke the 12 bolt in my Jimmy the 3rd time, it made good sense to buy the tools and do it myself. Over the years I have added to my tool collection and have paid for all of them by doing diff work for other people or additional installs for myself. I've probably done 20 for paying customers and another dozen for myself. At least.
You can get away with a minimum number of tools usually, but a carrier bearing puller and a good bearing separator are pretty much mandatory. Most likely, you will spend $500 on tools, but I never blink when it's time to buy a tool. It's hot rod parts that are complete dollar down the drain purchase.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-12-2019, 10:06 PM   #17
mongocanfly
on my truck im definatly doing the front myself....more than likely itll never to hardly ever be used...so close will be good enough on it
on my rear 14b im torn between paying to have it done or do it myself
a buddy told me he'd help me on it..he's probably done 30-40 gear swaps..never had any issues until the last 2....but im thinking about all the issues he's had on the last 2 he's done...one truck he did whined when he finished...he blamed it on cheap Chinese gears..he redid it with U.S. gears and no problems..
his last one I think hes redone at least 4 times and it still whines...3 different brands of gears in it and nothing has changed...still whines...he's talked to the gear manufacture and they don't have a answer....ive seen his setup patterns on all these and they look perfect...
the last one he added a ladder bar/coilover suspension on when he did the 1st gear swap..and now a guy told him the ladder bar rod ends are why hes hearing the whine..sounds like b.s. but who knows
Mongo...aka Greg
Old 02-12-2019, 10:06 PM   #18
Coley
Coley's Avatar
.....remember, don't try to open the 'cheap fart' garage.....those places don't last.
The trick to difficult, specific and high skill work is to recognize where your skills within it...start and stop, at least that is what I have learned.
I'm an extremely handy guy...and I'm essentially frugal in many areas...but I never have trouble paying for quality, specific work that is not in my immediate scope of ability.
This is particularly the case if the work is crucial and important and that if it doesn't go well....brings a boatload and days worth of annoyance, cost and effort to then redo it right.
One immediate example of this is the wiring of my basement. I'm not an electrician but I meticulously follow the local wiring codes and I did all the wiring...right up to 'almost' terminating the plugs and switches.
(Note; normally I do this on all my electrical work....but in this specific renovation, I wanted approved paperwork and the permits associated with it)
At this point...when it came to finalizing it and terminating everything at the plug/switch and in the sub-panel...I got an electrician to pull a permit, check it out and finalize it.
Easy peasy, good paperwork for insurance purposes....took a total of about 2-3 hrs not too expensive at all and it was the easiest, fastest, cleanest job the electrician had all week. Oh and did I say, I have the paperwork for insurance purposes in case there is a fire or whatever...this is important around these parts.
Anyhow, remember if its done wrong you might be buying everything involved twice....and I doubt a differential is a blast to work on and set up in the driveway, lol.
2000 Dodge Ram 1500
Old 02-12-2019, 11:48 PM   #19
cdub2010
Active Member
You got that axle done yet?
cdub2010 is offline   Reply With Quote
Old 02-13-2019, 01:01 PM   #20
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I dropped off a 12 bolt to my local Offroad shop that I had already cleaned and painted the empty housing, and I had installed the outer axle bearings and new axle seals. I supplied the new Limited Slip carrier, R&P, and new seal and bearing and shim kit. They charged my $250 bucks to set everything up.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
GASoline71 is offline   Reply With Quote
Old 02-13-2019, 01:03 PM   #21
PGSigns
PGSigns's Avatar
I have done a bunch of them over the years between mud racing and drag racing. I get $250 if its all clean when I get it. Thats for a 12 bolt or a dana. I will not put new stuff in a dirty housing. I also want all the parts including the backing plates and the axles. so I can put new axle bearings in and check the axle bearing surface. Nothing like getting blamed for a whinny gear when its got bad axle bearings in it. I also have been using the spacer kits that go in place of the crush sleeve. I think its a better way of getting bearing preload.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-13-2019, 01:35 PM   #22
YoungPup1977
YoungPup1977's Avatar
I often wonder why people don’t do the diffs themselves. They are so simple to do.
Also think of the guys who put out the money to buy the building, all the tools, and the experience to do a quality job. They didn’t get all this by setting up diffs for 200 bucks. Plus they have to pay the electric bill every month. I think most people don’t understand that but again they think most people should work as a hobby since it’s their hobby to say they are restoring their vehicle which in fact they are not. Plus complain they have to much money in their restoration. I hear it all the time. Shop fees 50 an hour if you help it’s 75 and dumb looks are still FREE !!!!
YoungPup1977 is offline   Reply With Quote
Old 02-13-2019, 02:31 PM   #23
sweetk30
sweetk30's Avatar
i also prefer to ditch the crush sleeve and go solid pinion spacer kit .
Old 02-13-2019, 09:56 PM   #24
burnin oil
Another vote for do the research and buy the tools. I have always been afraid to do axle gears because of the horror stories and I am very mechanically minded. I have rebuilt transmissions from 3 to 13 speeds, transfer cases, and more motors than I want to admit. Six months ago I did an 8.8 explorer swap into a jeep for the wife. It took me less than one day to pull the rear posi and rebuilt it and then regear the stock front axle. I got sick of pulling the chunk but it is really easy once you get the hang of it. My only regret is not going with 4.56 gears instead of the 4.10s. Actually getting the frozen ball joint out was worse than doing the regear.
burnin oil is offline   Reply With Quote
Old 02-14-2019, 10:38 PM   #25
BossHogg69
motor exploder
BossHogg69's Avatar
Great post. A man has to know his limits sometimes.
And $500 isn't a bad price if they are known for quality work and will back it up.
Adam
1969 Chevy CST/10 stepside, Dart Big M 532"BB/TREMEC Magnum Extreme
1965 Chevy Bel Air Wagon (daily driver), 350/TH350, factory a/c - and it works!
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/4.10's (date night cruiser)
2005 GMC ccsb 1500, 5.3/3.73 G80, tow pkg
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
