06-04-2017, 11:46 PM | #1 |
Dana 44 Carrier and Pinion Bearing Replacement Questions
I've been searching here and on the internet for the last couple of hours and I cannot find a definitive answer for this. If anyone here can steer me in the right direction, I thank you in advance!
I have been "going through" my 1974 Dana 44 K20 axle, replacing ball joints, seals, calipers and axle u joints. I had been reluctant to pull the carrier to do the inner axle seals but finally got the nerve to do it. Got the seals in, put the carrier in the parts washer and noticed that the carrier bearings are pitted as are the races. I can't put it back together like this and would like to replace the bearings. Im guessing that the pinion bearings are in the same condition and might as well do those too. My question is this. If I am only replacing the bearings, is it necessary to "set up" the carrier again? Or do I just pull the bearings, leaving the existing shims in place and press on the new bearings? These are the best pics of the bearings that I can get with my camera but the pitting is enough to catch a fingernail on which Im not thinking is good.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
06-04-2017, 11:54 PM | #2 |
60-66 Nut
Re: Dana 44 Carrier and Pinion Bearing Replacement Questions
I would just replace the bearings as you said with just keeping track of the shims. But when reassembled, I would check the gear pattern and see where it is at. The good thing is that being a front differential, it does not get used all the time.....or maybe it does in your case? So you may be alright if the gear pattern is not perfect.
06-05-2017, 12:27 AM | #3 |
Thanks Captainfab. I was worried Id mess something up by pulling the carrier for the inner seals. Had no idea that I'd be getting into bearings too. Looks like this axle was rode hard and put away wet! Looks like it had water sitting in it for a long time too.
I really hope this axle has run out of surprises for me.
06-05-2017, 07:40 AM | #4 |
The new pinion bearings will change the pinion depth some using the original shim . Probably not enough to worry about in this case. But the back lash needs to be the same . Need to measure it and duplicate when reinstalling . It can change quite a bit with new bearings on the carrier .
06-05-2017, 12:59 PM | #5 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
06-05-2017, 01:58 PM | #6 |
The dana 44 the carrier shims are inboard of the bearing cones not on the outside of the race like 12bolt. the pinion shims are the same behind the race. Not an easy setup to do. I would just put it back together as is. those bearings will last unless you are using 4wd all the time. save for the dana60. Good luck what ever you chose Chris.
Kimble
1961 chevy K10 my build is------------61K10 build Last edited by 61K10; 06-05-2017 at 02:03 PM. |
06-06-2017, 01:03 AM | #7 | |||
The most it will see is some muddy fire trails or snow a few times a year. Broken axles can be compensated for with big winches. Lol. Thanks for the advice Kimble. I hope Im at the end of the tuition payments on this axle. Any other surprises and Ill be running around with an empty front Dana 44 .
