01-17-2017, 04:14 PM | #1 |
Tf 55-59 With M2 headers on LS engine?? Help
HI
Im curious if anyone put headers on a TF Truck with a mustang 2 front suspension with a LS engine... I"m trying to get an idea of what one to buy and trying not to buy a pair and not be able to use them.. If anyones done anything like this or something close let me know!! I've looked up the projects but havent found anything and searched.. Thanks and Thanks! |
01-17-2017, 05:28 PM | #2 |
Junior Member
Re: Tf 55-59 With M2 headers on LS engine?? Help
I tried Pacesetter 70-2259, they fit but the steering linkage was not going to work very well. My motor sits about an inch forward of where it should be and that may be why.
I ended up using the Hooker cast iron items, no problems. |
01-17-2017, 05:32 PM | #3 |
do you really want headers or is it that you just can't find manifolds to fit between the frame rails? I used 2000 camaro manifolds and they fit with room to spare.
01-17-2017, 05:38 PM | #4 |
here are a couple of pics in my 57
01-17-2017, 06:49 PM | #5 |
I'm looking for headers but that is great to see about the camaro manifolds.. are the manifolds off 98-02 camaro or the 2009 and newer? Thanks always good to have something in the pocket.. thanks
01-17-2017, 08:41 PM | #6 |
they were off a 2000 camaro.
01-26-2017, 12:54 PM | #7 |
I used 2011 Camaro manifolds and they clear nicely. I went from the nightmare of 4 u joints with a heim joint to 2 u joints and a straight DD.
These are on ZL1 Camaros as well, so they flow 500+ HP. |
01-31-2017, 08:35 AM | #8 |
holly hooker ls swap headers fit awesome. and you can get them in ceramic coated.
1959 Chevy Apache (sold) 1958 Fleetside Current My builds: http://67-72chevytrucks.com/vboard/s...d.php?t=606412 http://67-72chevytrucks.com/vboard/s...=1#post7560906 |
01-31-2017, 10:03 AM | #9 |
08-14-2017, 01:33 AM | #10 |
interested if you ever found a set that fit. I'm installing an ls in my scotts hotrods equipped 57 soon and need to find out what works. Thanks
HOTROD HOODLUM |
08-14-2017, 06:25 PM | #11 | |
I love the headers and the fit is great and shouldnt be a problem with the steering column too with only two knuckles. I'll post pics when i get that far or I might have one up on my build too. Joe |
08-14-2017, 09:26 PM | #12 |
Awesome. Do you know if they hang below the rockers at all? clear motor mounts ok?
HOTROD HOODLUM |
08-14-2017, 11:26 PM | #13 |
MIne clear the engine mounts no problem and not sure in the rockers.
Here's some pics when I had the engine in which will be soon again http://67-72chevytrucks.com/vboard/s...=695061&page=2 |
08-15-2017, 12:06 AM | #14 | |
HOTROD HOODLUM |
08-18-2017, 11:24 AM | #15 | |
