08-26-2009, 11:16 PM | #26 |
Re: eaton rear axle
And now you know why people dump their very strong Eaton rear ends. Getting parts is a big headache.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
08-27-2009, 12:38 PM | #27 |
Re: eaton rear axle
Yeah, I thought there were enough of those old eatons to support replacement parts, guess not.
08-27-2009, 04:12 PM | #28 |
its all about the +6 inches
Re: eaton rear axle
they stopped making them in 72. There's hardly any on the road when you look at the big picture
08-29-2009, 01:48 AM | #29 |
What?
Re: eaton rear axle
Yea, they are a stout axle. But they are a dying breed, and after all my hassle of trying to find parts... I think if it breaks it will be time to just replace it with something more comon next time around.
Just doing a complete brake overhaul, has kept my burb on jackstands for the last month or so just trying to hunt down parts. It's been very frustrating for me these past few days, to just do something as routine as a brake overhaul. Granted I was missing these parts to begin with, and I am trying to make them right now.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
08-29-2009, 02:38 AM | #30 |
Re: eaton rear axle
if i was going to go a different route than the corporate axle, i'd skip the dana and all the other ho hum alternatives and go right for a 14 bolt full floater from a 2000 or newer GM truck. 11.5 ring gear (older 14bff has a 10.5) and disc brakes that are much better suited to our trucks than some hodge podge type using an aftermarket bracket and a lame excuse for an e-brake (the brake should not be in the caliper.....just asking for trouble).
08-29-2009, 02:48 AM | #31 |
Re: eaton rear axle
From everything I have read about the Eatons, if you have brake trouble that is more than a simple brake job, go with disc brakes. The 14 bolt conversion parts fit the Eatons. Or replace the rear with a Dana or 14 bolt. Too bad really, the Eaton was a good design.
09-26-2009, 10:06 PM | #32 |
Re: eaton rear axle
I think these are great axles. I like the removable carrier, yet you can still pull the rear cover and take a look or change fluid. Got one in my stock 67 C-20 still going strong.
09-27-2009, 01:06 AM | #33 |
Re: eaton rear axle
they are awesome rear ends... till you need parts, or more than a 4.10 gear.
Mine is getting tossed in favor of a 14 bolt |
11-29-2010, 01:14 AM | #34 |
Re: eaton rear axle
I have 5.14's from the HO72 in my 1951 3800 pickup ( 1ton) . Any body got a current line on the 3.90 ( aftermarket) supplier?? Anyone got 4.10 center section and need 5.14's ???. I can pull anything even with this 235 engine but 46 is about top speed without hurting it.I would like to be able to run road speed and not hurt it . Not really intrested in swapping for a 14 bolt, dana etc,
thanks LMD |
11-29-2010, 07:54 PM | #35 |
Re: eaton rear axle
i would have gone with the aftermarket 3.90 ratio if it was still available but it was convenient being able to just plug and play with a whole third member all set up to get from a 4.57 to a 4.10 in my 72 burb c20. that 10% improvement makes highway driving livable but i'm still wishing for an overdrive on long trips. if my truck had been a floor shift model instead of the 3 on the tree (that i want to keep) i would have gone for a more up to date trans.
in your case another option might be to invest in a modern 6 speed...you can get one with a mechanical clutch. the 6th gear is available in a couple super soft ratios. only issue would be the fact that the drive shaft rpm is still governed by the rear axle ratio (more vibration). but you'd have the best of both worlds and that little 235 would feel more like a 292! 3.73 x .7 (700r4) = 2.61 5.14 x .52 (6 spd) = 2.63 |
11-29-2010, 08:22 PM | #36 |
Re: eaton rear axle
Resurrection round 2!
