06-28-2017, 09:21 PM | #1 |
fan
49 ad with stock 283 aluminum radiator. can I run an engine driven fan
with offset fan shroud. [fan is low on radiator] I have room but my buddy said an offset fan shroud might not pull enough air from the top of the rad. I think it will work, what do you guys think |
06-29-2017, 08:39 AM | #2 |
Re: fan
so has anyone run a v8 with engine driven fan in an ad
06-30-2017, 12:06 PM | #3 |
Re: fan
oh well
06-30-2017, 06:21 PM | #4 |
Re: fan
I did for years with no shroud. First with the stock core and then with a 2-1/2 ton truck core in my tanks. I never had a cooling problem with that setup until the radiator died of old age and probably vibration as I had left some of the support off in the subframe swap.
I'm thinking that the stock 1-1/2 ton shroud I have out here isn't centered on the core. I did without problems. Stock radiator with a 283 and I am thinking a fiberglass flex fan. I went though a lot of those as they were always cracking blades. A shroud with an offset hole should work ok if it is designed so the air can flow to the fan. This is the stock shroud on a 1-1/2 ton. Note that there is a pretty decent space between the shroud and the core. At least 2-1/2 inches of space for the air to move in the corners.
06-30-2017, 09:52 PM | #5 |
Re: fan
building one almost identical to that . thanks for posting
07-04-2017, 09:43 PM | #6 |
Re: fan
i have a v8 with engine driven fan, no shroud, no problems
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 |
07-04-2017, 10:18 PM | #7 |
Re: fan
hot water is at the top. best place to cool it. I've got a 54 with MII clip and SBC under construction right now, when I saw how low the fan was I ordered up a 16" electric. installed but not driven yet. It has A/C and it's like 108 outside so it won't take long to find out.
