06-12-2017, 03:01 PM | #1 |
Good place to buy black "phosphate" washers & nuts?
I'd like to load up on new flat washers, lock washers and nuts, grades 5 & 8, in black phosphate. Few questions/points
1. Seems black oxide is far more common than phosphate. Far as I know, phosphate is superior black oxide. 2. With my search I getting mixed results. For instance, Fastenal has some black oxide lock washers, though not all the common sizes (e.g., 7/16 & 5/8). Additionally, there's no mention of grade, so I assume they're grade 2. Auveco seems to come up short as well. 3. Anyone advise of a good single source for black washers and nuts in the correct sizes, whether phosphate or oxide? Perhaps black zinc? Thanks
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
06-12-2017, 04:17 PM | #2 |
Re: Good place to buy black "phosphate" washers & nuts?
Talk to fastenal..our work gets all our black bolts thru them..any size any grade..we use grade 5 and 8..
06-12-2017, 04:36 PM | #3 |
https://www.re-fastener.com/Category...ODY%20HARDWARE
http://knoxvillebolt.com/ https://www.finishing.com/237/42.shtml http://www.nuttybolts.com/fasteners/...6-p-18669.html https://www.albanycountyfasteners.co...als-s/1129.htm https://www.amazon.com/Cap-Screws-He...%3A15245615011 That should keep you busy Last edited by Grumpy old man; 06-12-2017 at 04:49 PM. |
06-13-2017, 12:16 AM | #4 |
Thanks for the info.
Still digesting all what Grumps provided. Learned one thing, hot black oxide stainless is a great option.
06-13-2017, 09:54 AM | #5 |
I,ve seen some DIY plating on bolts on u tube but not sure on the black you want but there was zinc and some others that looked easy
06-13-2017, 05:05 PM | #6 |
blood type; Retumbo
I'd look into making my own black phosphate hardware.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
06-26-2017, 01:30 PM | #7 |
i buy lots of these bolts from the "bolt barn " on the internet or e-bay ! i like to use the non plastic lock nuts w/ the flange on them ! i do a lot of trucks -sometimes they need the spring hangers or crossmember removed to clean up rust ! & i have to cut the rivets sometimes ! so on assembly i just use those plated bolts -sure looks better that the factory stuff !!!!
