11-19-2018, 10:12 PM | #1 |
Wiring Diagram/Pinout Help
Can anybody help me find the pin out for an ACDelco 22873153 wiper motor? The OE fitment is C7 Corvette. The wiper motor only has a 5 pin connector.
I have successfully identified the Ground, Slow, and Fast pins. One of the other pins definitely controls Park functionality, but I can't quite get the whole thing working correctly and I believe the unidentified 5th pins holds the answer! Thank you in advance. |
11-20-2018, 03:19 AM | #2 |
Msgt USAF Ret
Re: Wiring Diagram/Pinout Help
This is a picture of the motor with the pins.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
11-20-2018, 07:45 AM | #3 |
Thanks for the reply but that is a different motor. I reapply need some help understanding how the 2 park pins function together.
11-20-2018, 11:21 AM | #4 | |
Msgt USAF Ret
Are you talking about the wiring pins or the mechanical pins inside the motor. This is the internal pins but not sure if they are for the C7. https://www.google.com/search?q=how+...ybSIQFNt0hmAM:
11-20-2018, 11:33 AM | #5 |
Msgt USAF Ret
Here's a little icing for the cake, They might be useful for your vette if you do your own work.
https://www.corvetteforum.com/forums...-stingray.html After reading your OP again I am not sure if you are just using the wiper motor out of a C7 or if it's for your C7. So if it;s the former then maybe the links will help other members.
11-20-2018, 07:08 PM | #6 |
I was referring to the terminals on the electrical connector. I am just using the c7 motor on a classic car application to add a modern motor and intermittent delay functionality while I'm at it.
