Old 11-29-2018, 03:28 PM   #1
ChadW
1964 327 pcv setup
Have a cpl questions regarding the pcv setup for a 327...I have the little "dixie cup" attachment for the block and was planning to use it with a hose off of it to a inline pcv valve and connect it to the carb or carb spacer...I am running a performer intake and there is no oil filler neck/breather. So i take it this means i will need to run a breather on my valve covers, correct? Am i setting this up right? do i need breathers on both valve covers?
ChadW is offline   Reply With Quote
Old 11-29-2018, 03:35 PM   #2
geezer#99
geezer#99's Avatar
Re: 1964 327 pcv setup
Yup! Just one breather on one valve cover will work with your rear pcv.
Old 11-29-2018, 04:34 PM   #3
mattfranklin
mattfranklin's Avatar
Yes, and if it makes sense, figure out how to put the fresh air inlet in such a way that it sweeps all of the nasty crankcase fumes toward where the PCV valve is. The fresher your crankcase is, the longer the oil stays good.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 11-30-2018, 11:40 AM   #4
ChadW
is a pcv a pcv or do i have to get the proper one for my motor? I cant seem to locate an inline one.
Old 11-30-2018, 11:46 AM   #5
geezer#99
geezer#99's Avatar
Lots right here.
https://www.google.com/search?tbm=is...30.shaG5urKfTY
Old 11-30-2018, 11:52 AM   #6
mattfranklin
I think as long as the engine size is in the right range you're probably ok.
If it were me and I needed an inline one I'd consider this one: Standard Motor PCV Valves V112 https://www.summitracing.com/parts/s...QaArL8EALw_wcB
I put the Summit link there more for reference. I'd guess the shipping would be way more than the $4 part cost. You can cross reference it and get one at your local parts place. It looks like it might be good because one of the applications is a Buick 350.
Old 11-30-2018, 02:38 PM   #7
mrtoni
That year 327 should have road draft tube off back of intake no pcv in valve cover
mrtoni is offline   Reply With Quote
Old 12-01-2018, 07:41 AM   #8
Dead Parrot
If you are trying to retrofit a PCV setup, easiest is to get a set of valve covers from a few years newer SBC. They will have the proper holes for both a breather and PCV valve and you will be using standard parts instead of trying to improvise something. Then you can just plug the draft tube.
I had a 68 Impala with a 327. PCV valve was on the driver's side valve cover and the breather hose ran from the passenger side cover to a small filter in the air filter housing.
Dead Parrot is offline   Reply With Quote
