12-02-2018, 12:48 PM | #1 |
which harness??
Hi guys,
I have a '51 5 window that I will be doing a modern drive train and suspension on, but I don't have a clue as to which new harness I should use! Just how many "circuits" do I need? Power windows and locks are only a remote possibility. Thank you for any light you can shine on this Redraider |
12-02-2018, 01:09 PM | #2 | |
Old member
Re: which harness??
As far as the motor and transmission goes depending on what you are buying. If your doing a LS swap then by a stand alone harness and your good, you then use what's in the truck now also. The stand alone will run the motor & transmission. If you want to monitor the motor stuff buy a Scan gauage 2 are a simaliar product. This link has a bunch of info. http://67-72chevytrucks.com/vboard/f...ysprune=&f=206
