Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 12-08-2018, 01:44 PM   #1
7DShortBed
7DShortBed's Avatar
Wiring Problem?
I`m having an issue with losing my left side brake light when lights are turned on. I have brake lights without lights on but as soon as I turn on running lights and step on brake the running light goes out and no brake light either.
Any ideas? This is a new rear light harness from Lmc truck
7DShortBed is offline   Reply With Quote
Old 12-09-2018, 04:22 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Wiring Problem?
What does the right side do? If it works ok then I would check the grounding on the left side socket to bed mount .
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-09-2018, 10:09 PM   #3
damnyankee36
damnyankee36's Avatar
Re: Wiring Problem?
Agree. Symptoms like these are typical indicators of ground issues, usually at the tail light housings as VetteVet said.
damnyankee36 is offline   Reply With Quote
Old 12-10-2018, 10:19 AM   #4
7DShortBed
7DShortBed's Avatar
Re: Wiring Problem?
I think I found it. It`s in the molded plug that connects everything to the
feed from front of cab on the NEW LMC taillight harness. I pulled light socket
from left side, left it hanging, went turned on running lights and I held bulb to socket and it lit up?
Not supposed to do that! So I went and got the old junk harness, plug that in to taillamp housing laying on floor, ran a ground wire to
ground housing, turn lights on and I had brake and taillight. Started to check
new plug wires and found I had continuity between brown light wire and green
reverse wire in brown wire plug slot. Don`t have it with factory plug so
I`m going to cut off the old NOS plug and connect to my new Taiwanese
harness. I lost a lot of hair scratching my head on this one.
Another reason to use the old stuff or NOS. Aftermarket crap!
Thread Tools
Display Modes
